69 Starter wiring help needed! - Team Camaro Tech
post #1 of 8 (permalink) Old Dec 10th, 07, 08:02 AM Thread Starter
I bought an 87 Monte Carlo with a ZZ4 so I could take the drivetrain for the Camaro. I've swapped everything over and am trying to sort out the wiring to get it running. The problem I am currently trying to solve is with the starter. I have searched the site and it seems the original starter had 2 smaller posts. The starter that is on the engine was in the Monte and only has 1 small post. Is there a way to work this with the original wiring or would it be easier to buy an original starter?
03glide is offline
post #2 of 8 (permalink) Old Dec 10th, 07, 08:12 AM
prostreet69camaro's Avatar
Re: 69 Starter wiring help needed!
The starter you have will work fine. The original starter with 2 small terminals is for a old style point distrubutor. All you need is the wire to go to the S terminal. The R is not used. If you have the 2 wires in your harness just tape up the yellow wire and the purple goes to the S terminal. The original yellow wire went from the positive of the coil to the R terminal on the starter.
prostreet69camaro is offline
post #3 of 8 (permalink) Old Dec 10th, 07, 08:13 AM Thread Starter
Thanks for the quick response.
03glide is offline
post #4 of 8 (permalink) Old Dec 10th, 07, 08:48 AM Thread Starter
Checked the purple wire and it is hot with the key "on". Wouldn't this cause the starter to engage as soon as I hook it up? I only have the wiring harness partially connected. The headlights and marker light connections are all loose. Could a ground not being connected be causing some problems. I have the neg battery terminal grounded the the block and attached to the core support. The positive is connected to the starter and the junction block.
03glide is offline
post #5 of 8 (permalink) Old Dec 10th, 07, 11:51 AM
Harry
dawg's Avatar
do not cut the yellow wire!
that goes with the purple it provides the current etc to the ignition .
otherwise youll be in start and the dist wont get juice until you release the key to the run position.
look here for diagrams etc.
http://www.camarosource.ca/forums/vi...15ec639b6d0b38
434 stroker
US Navy retired
dawg is offline
post #6 of 8 (permalink) Old Dec 11th, 07, 08:42 PM
Jon
Rodder's Avatar
Send a message via AIM to Rodder Send a message via Yahoo to Rodder
If he had a '67, that'd be true... unlike '67, 68 and up ignition switches power the "RUN" circuit in both START and RUN positions.
(actually was this change made mid-year in '67? I vaguely remember reading something about that)
- LS1, T56, Hooker longtubes, Autokraft pan & mounts, GM LS7 clutch, Borla ProXS, Moser/Strange/Wilwood 9", Covans dash, UltraLite IIs, Procar Elites, Vintage Air GEN-IV, AGR 12:1 steering, Addco swaybars, Hydratech hydroboost
Rodder is offline
post #7 of 8 (permalink) Old Dec 11th, 07, 09:28 PM
The purple wire should NOT have power when the key is in "run" only in start. If it does, there is something else wrong and yes, your kar would crank all the time, a bad thing.
And no, you don't need the yellow wire on a 69. You will need to remove and rpelace the factory resister wire to the coil tho.
post #8 of 8 (permalink) Old Dec 11th, 07, 09:31 PM
Don't know it for sure, but think so.
Absolutely lots of 67's don't power the IGN circuit in crank, but I owned one 20 years ago that did... I think? or maybe I kept the yellow wire when I put the hei in it? it was a long long time ago. 'Bout all I remember is hacking of the resister wire and hooking on a big honkin wire...lol.
Do our resto experts ever peek in here?
