STILL confused wiring my tach - Team Camaro Tech
post #1 of 4 (permalink) Old Dec 10th, 07, 07:09 PM Thread Starter
Okay, after following all the wiring instructions that are posted, Im still confused exactly how to wire my factory tach in my 67 Camaro.
Do I have to run to separate wires off the back of the tach??. I followed the instructions of changing the plug wire in the back of the pod then connecting from the firewall plug to the coil. Still no power/rpm at the tach when I start the engine. Again any help is greatly appreciated. Im a little lost. I definately need step by step instruction. Bruce.
Brucecc1967 is offline
post #2 of 4 (permalink) Old Dec 10th, 07, 08:40 PM
Kevin
Re: STILL confused wiring my tach
Do you have it grounded?
Learning & Relearning about the cars I grew up with.
69' - Built 350, 750 Holley, Elgin E920P Cam, 283 PP Heads, Long Comp Headers, MSD, TKO-600, 12 Bolt Posi 3.73, Hotchkis Rear, Eibach Front w/Hotchkis Sway, SPC UCAs, 3rd Gen PS, AR TTII's. Still working on it.
dbx1969 is offline
post #3 of 4 (permalink) Old Dec 10th, 07, 09:32 PM
The 67 tach attaches to the same wiring the fuel gauge used. It recieves it's power and ground thru the same lugs the fuel gauge did. The tan wire coming out of the cluster harness connector needs to be cut and rerouted to the +coil terminal and the tach will work.
The other end of the tan wire needs to go to the new fuel guage.
post #4 of 4 (permalink) Old Dec 19th, 07, 03:51 PM Thread Starter
sorry for not posting back sooner. Thanks for the info. I will let you know. Thanks again.
