Instrument Panel Connector - Team Camaro Tech
post #1 of 6 (permalink) Old Dec 11th, 07, 07:39 AM Thread Starter
Anyone know where I can get the female connector to the 67 instrument panel (same one that is part of the printed circuit board)?
I'm in the process of upgrading/restoring/modifing/and repairing a 67 coupe, and am installing the Covan panel with Auto Meter gages. I can just cut the male off the harness an put my own connector in, but thought I may be able to get the one tha just mates with the current harness.
Thanks,
Russ67
Russ67 is offline
post #2 of 6 (permalink) Old Dec 11th, 07, 08:48 PM
Jon
Rodder's Avatar
Send a message via AIM to Rodder Send a message via Yahoo to Rodder
Re: Instrument Panel Connector
Never seen one... you could probably fab something in an afternoon by etching two circuit boards and putting a bracket between them.
I ended up cutting the harness off my connector and putting a Metripack on it to go to my Covan's panel.
- LS1, T56, Hooker longtubes, Autokraft pan & mounts, GM LS7 clutch, Borla ProXS, Moser/Strange/Wilwood 9", Covans dash, UltraLite IIs, Procar Elites, Vintage Air GEN-IV, AGR 12:1 steering, Addco swaybars, Hydratech hydroboost
Rodder is offline
post #3 of 6 (permalink) Old Dec 11th, 07, 09:23 PM
The connector IS the PCB, along with the vutout in the panel behind it. There's nothing else there.
post #4 of 6 (permalink) Old Dec 12th, 07, 12:52 PM
You can purchase white molex connectors with crimp on pins if your doing a custom job. But the mylar PWB on the back of the gauge cluster is a custom job and must be mated with the OEM connector. I'm not sure exactly what you're trying to do, but the Molex connector may serve your need. Do a search for molex on http://www.digikey.com for example - there are a few other suppliers out there as well.
dnult is offline
post #5 of 6 (permalink) Old Dec 12th, 07, 02:40 PM
If you decide not to use the male connector let me know. I need one. The guys that were restoring my car threw out the old wiring harness with connectors and all. i am using a aftermarket wiring harness that doesnt have any connectors to go back to the original speedometer or gauges.
Thanks,
JOHNRSWEAT is offline
post #6 of 6 (permalink) Old Dec 12th, 07, 04:42 PM Thread Starter
Thanks all for the replies. I just purchased a Radio Shack 12 pin male/female and will go that way.
JOHNRSWEAT: I'll let you know about the male connector, but for now I may keep it just in case I get that offer I can't refuse and someone wants to return it to orignal. I'm doing so many other mods it may not matter anyway. I'll let you know soon.
Thanks again.
Russ67
Russ67 is offline
