Cleaning original wiring harness - Team Camaro Tech
post #1 of 6 (permalink) Old Dec 12th, 07, 06:44 PM Thread Starter
Timothy
I want to clean my still usable wiring harness. I was planning on using mineral spirits but Im afraid whatever I use might cause the wire jackets to crack prematurely. So I was thinking instead I would use laundry detergent. They wont come out as clean but I should be able to remove most sludge and road dirt before recovering them. Does that seem like a better plan?
Also where do you get the non stick tape from?
TIA
My 69 RS/SS 396 Project -
"I may be dumb but I aint stupid"
Microgiant is offline
post #2 of 6 (permalink) Old Dec 12th, 07, 07:04 PM
Banned
Ron
Badbird's Avatar
Re: Cleaning original wiring harness
I have the complete OEM wiring for my 68 coupe laying around in the garage.....I rewired with the Painless 18 circuit wiring kit.....Anyways, I was thinking of cleaning it up and adding the necessary sockets it needs and selling it.....What I was thinking of doing is just cleaning and/or wiping them down and re-wraping with that non stick black tape and also black electrical tape.....I believe it would look like a brand new stock, original OEM wiring kit!.....Let me know if anyone would be interested in purchasing them either now or when I restore them.
Badbird is offline
post #3 of 6 (permalink) Old Dec 12th, 07, 07:12 PM
Greg
You can use any type degreaser on the wires, 409, etc, and the non stick wrap from any of the 1st gen houses, got mine from Firewheel.
1969 RS/SS Vert
1031 Engineering llc
chops is offline
post #4 of 6 (permalink) Old Dec 12th, 07, 07:13 PM
I did mine exactly that way.
When you unwrap it, be sure to measure accurately from the firewall connector for the length of each "branch" and note which wires came out there, so you can put it back together the way it came apart. When I cleaned my garage, I found the "map" in a drawer somewhere.
My harness was messy. The wires and terminals were good, but there was LOTS of paint overspray. A certain amount of black spray bomb, and here and there some blue urethane.
I started with 409 and got each wire as clean as I could. Mineral spirits took the black off. The blue was VERY tough, used laquer thinner and a scotchbrite pad and a lot of elbow grease on that.
I replaced any bad or hacked up wires (purple one to starter, damn those get beat up!) ran a real wire for my electronic ignition, ran a couple spares from near the horn relay to the firewall for future upgrades, and wrapped the 4 guage feed for my power amps inside the lighting harness.
I also carefully removed every terminal, cleaned it till shiny again (scotchbrite mostly, a lil wire wheel in a dremel on some, others needed replacing, got the terminals at napa.) and put em back (Don't forget to bend the tang back out so they stay put.)
I got the no-stick tape from D&R (drclassic.com) but I'm sure all the repro houses carry it. They had 2 widths, I used 1", seemed it'd be easier that way.
The finished harnesses look factory new. They also work perfectly.
post #5 of 6 (permalink) Old Dec 12th, 07, 08:26 PM
Frank
Laquer thinner is the best. Makes them absolutly new again, and does not hurt the protective coating.
ProdigyCustoms is offline
post #6 of 6 (permalink) Old Dec 12th, 07, 09:27 PM
Send a message via AIM to RamAirDave
What I do is similar, but I put a single wrap of elec tape every 6-8" or so, and directly on either side of every "branch".
That way it still stays together, and in its correct configuration.
Driving a #s-matching Z in the rain..... and lovin' it....
RamAirDave is offline
