What's this ???? - Team Camaro Tech
post #1 of 8 (permalink) Old Dec 15th, 07, 11:23 AM Thread Starter
What's this ????
Took out alarm which wasn't a problem at all
The problem is that under the dash was the "brain" of the alarm and it was spliced into a heavy guage purple wire (cut and both ends wired into the box). I removed everything and didn't reconnect the wires but the car still starts in park and neutral but not in gear. No problems with lights,turn signals,idiot lights, or ect.
I tried testing it with a volt meter and it shows no power in any key position (Acc,on,or start)
What's it for ? (it is a factory wire I know)
68 Camaro~LSx ~all motor
post #2 of 8 (permalink) Old Dec 15th, 07, 11:26 AM
Kevin
KevinW's Avatar
Re: What's this ????
Usually the heavy purple is for the neutral safety switch. Used to only start cars in park (auto) or clutch pressed in (manuals).
Kevin
KevinW is offline
post #3 of 8 (permalink) Old Dec 15th, 07, 02:03 PM Thread Starter
Thats what I thought but wasn't sure and car starts fine. I can only guess if I connect the two it wouldn't ?
I'll just cap them off.
Thanks.
post #4 of 8 (permalink) Old Dec 15th, 07, 07:16 PM
That is too weird Doug.
Those wires are for the starter, and they would need to be connected together for it to start. I'd guess the alarm box has a relay to disconnect them to disable the starter when the alarm goes off.
I'm real uncomfortable that it will still start. I think you should do some more checking and see exactly what is going on.
post #5 of 8 (permalink) Old Dec 15th, 07, 09:01 PM Thread Starter
It started up fine too
post #6 of 8 (permalink) Old Dec 16th, 07, 04:10 PM
prostreet69camaro's Avatar
I agree with Jim. If those wires are cut you should not be able to start your motor. They are for the starting circuit and go thru your nuetral safety switch.
prostreet69camaro is offline
post #7 of 8 (permalink) Old Dec 16th, 07, 05:22 PM
Did this alarm have a remote start feature? Jb
Beat it to Fit, Paint it to Match!
Johnny B is offline
post #8 of 8 (permalink) Old Dec 18th, 07, 03:17 PM Thread Starter
No, only a starter interrupt, valet (like I would let someone else drive it :noway ),shock sensor, and hood/trunk/door pin switches.
