cluster removal - Team Camaro Tech
post #1 of 7 (permalink) Old Dec 29th, 07, 09:51 PM Thread Starter
Ken
cluster removal
can the dash cluster be removed fairly easily?I tried last summer and it looked like the dash pad had to come off so I quit for now.Now though I want to install the tach I am buying before summer.
kgmunro is offline
post #2 of 7 (permalink) Old Dec 29th, 07, 09:56 PM
Rob
no69x-44's Avatar
Re: cluster removal
If you are careful enough you can get the dash cluster out without removing the pad. You will however need to remove all the screws from the cluster and drop the steering column some in order to get the dash cluster out.
no69x-44 is offline
post #3 of 7 (permalink) Old Dec 29th, 07, 10:04 PM
Re: cluster removal
what year?
guccieng is offline
post #4 of 7 (permalink) Old Dec 29th, 07, 11:14 PM
Ron
Re: cluster removal
You have to drop the Steering Column in a 2nd Gen or you not only break of the Cluster Pod mounting tabs but risk burning the car down when you short out the wires when you break off the head light switch because you didn't disconnect the battery. Scratching the steering column all to ratchet with the Cluster will be the least of your problems - LOL
This was my 70 1/2 Z28
Z15CAM is offline
post #5 of 7 (permalink) Old Dec 30th, 07, 06:07 AM Thread Starter
Ken
Re: cluster removal
sorry,I forgot to mension mine is a 69.
ken.
kgmunro is offline
post #6 of 7 (permalink) Old Dec 30th, 07, 08:50 AM
Kevin
Re: cluster removal
You can install your tach without removing the dash at all. I think removing the dash is one of those things that just becomes "the way to do it" and nobody questions it. I know it flies in the face of conventional wisdom around here, but I did it earlier this year. In fact, after installing it with the dash in, I can't imagine why anyone would want to remove the dash to do this!
Assuming you're replacing the gas gauge with a tach:
1. Take out the 4 screws that hold the plastic face on.
2. Remove the 3 nuts off back of gas gauge & remove gauge
3. Use a scaled template cut-out and line up with the 3 holes
4. Drill 3 holes and cut out tach pattern with milling bit in a dremel (make sure wires behind dash are securely out of the way).
5. Install new tach & use wires from old gauge harness clip
6. Replace plastic face guard. Done.
It's not exactly a walk in the park, but it's pretty straight forward. No way in hell I'd take the dash cluster out to do this.
Learning & Relearning about the cars I grew up with.
69' - Built 350, 750 Holley, Elgin E920P Cam, 283 PP Heads, Long Comp Headers, MSD, TKO-600, 12 Bolt Posi 3.73, Hotchkis Rear, Eibach Front w/Hotchkis Sway, SPC UCAs, 3rd Gen PS, AR TTII's. Still working on it.
dbx1969 is offline
post #7 of 7 (permalink) Old Dec 30th, 07, 10:48 AM Thread Starter
Ken
Re: cluster removal
I think I will give it a try that way,sounds better than removing the dash.
kgmunro is offline
