1988 IROC Z-28 350 Camaro - Team Camaro Tech
post #1 of 4 (permalink) Old Jan 1st, 08, 09:38 AM Thread Starter
Help.! I have an '88 IROC Z-28 5.7 TPI Camaro and the dash light(s) went out last week. Here's all I know at present: All headlights work except the right side high beam - replaced the headlight, but high beam still won't work? All tail lights work. (This may or may not be related to my main problem - the dash lights.) Inside the car, the "Service Engine Soon" light stays on all the time the engine is running. That didn't particularly bother me, as the car runs like a bat out of h***. However, the dash lights went out about a week ago, which makes it near impossible to drive at night. The right/left floor lights still work, & the dome light with the two reading lamps still work. All fuses under the driver side by the steering wheel are okay. I know next to nothing about cars, so my question is, are there other fuses and/or relays I can check first before the repair shop sees me coming with my wallet open?! (I don't own any meters to check things out, etc.) Thanks!!!
LWTW70 is offline
post #2 of 4 (permalink) Old Jan 1st, 08, 05:00 PM
Re: 1988 IROC Z-28 350 Camaro
check all ground wires
1967 RS convert 88,000 original miles numbers matching 327 powerglide
DDOLES is offline
post #3 of 4 (permalink) Old Jan 1st, 08, 05:22 PM
Mitch
Lost in the 60's's Avatar
I'm going to start very basic here and ask if you, or anyone else, may have dimmed the dash lights down to nothing with the headlight knob ?? It could be the headlight switch has failed internally too. The dash lights work thru a fuse, so if they are all good, I doubt it's a short, but it could be a broken wire or circuit panel too.
Good luck....
...38 Chev coupe, street rod
...54 Chev 210 coupe
...62 Impala SS, driver/project
...67 Camaro, ss/rs LA built driver/project
...66 Chevelle SS, Atlanta built 138 driver/project
...69 C10, cab and clip may end up on the '89 rollback
...70 Chevelle SS, Canadian documented Z25 project
Lost in the 60's is offline
post #4 of 4 (permalink) Old Jan 8th, 08, 05:14 PM
scblucam's Avatar
I don't think this is it , but in my 85 IROC the harness inside the tilt column shorted and caused all kinds of misery.
scblucam is online now
