Where do these wires go to? - Team Camaro Tech
post #1 of 9 (permalink) Old Jan 1st, 08, 06:50 PM Thread Starter
I have 2 wires from the dash harness that I can't figure out where they go. The first one is a thick brown wire around the ashtray(is it the ground for the cigar lighter? It is thicker than the cigar lighter orange power wire) The second is a thin brown wire coming out of the ubderdash harness right next to the fuse panel. It has a grommet on it like it would go through the firewall.
http://i243.photobucket.com/albums/f...1111111004.jpg
http://i243.photobucket.com/albums/f...1111111001.jpg
brad900 is offline
post #2 of 9 (permalink) Old Jan 1st, 08, 07:13 PM
Re: Where do these wires go to?
I say the brown wire is 14awg and it goes to the heater contol switch and the other with the groumet I don't know.
doctordiode is offline
post #3 of 9 (permalink) Old Jan 1st, 08, 07:45 PM Thread Starter
The heater switch already has its connector on it. It must be a high consumer because of its wire size.
brad900 is offline
post #4 of 9 (permalink) Old Jan 1st, 08, 08:17 PM
ok there is another wire around there that is 16awg and it goes to the generator lamp but I don't know if is the same type of connector. you may want to check that. it has to be one of these to because I'm looking at the wiring schematic. also I need to know if this car has air conditioning.
post #5 of 9 (permalink) Old Jan 1st, 08, 08:52 PM Thread Starter
no a/c. no console. the harness is for a factory tach 4 speed
brad900 is offline
post #6 of 9 (permalink) Old Jan 1st, 08, 09:31 PM
69 L 89 RAG's Avatar
The wire with the grommet looks to be the tach lead wire the end shown in picture hooks up to the distributor (-) side.
Never under estimate the extended reach of a woman with a rolling pin !
69 L 89 RAG is offline
post #7 of 9 (permalink) Old Jan 2nd, 08, 05:36 AM
Bingo on the one. Tach wire.
No joy here on the other one.
post #8 of 9 (permalink) Old Jan 2nd, 08, 02:39 PM Thread Starter
Yeah I thought that 1 wire most have likely gone through the firewall but I wanted to make sure. I guess I can call the harness manufacture to find out the other one
Brad
brad900 is offline
post #9 of 9 (permalink) Old Jan 2nd, 08, 07:24 PM Thread Starter
OK I think I figured it out after reading the whole AIM. It looks like it plugs in to the a/c harness for cars with a/c. On page 234 of the AIM it shows the 14ga brown wire coming from the fuse panel & says wire is part of instrument harness. The connector that plugs into this says it is part of the a/c harness & it goes to the low blower switch. I email factory fit to verify. What would we do without the AIM!!!
brad900 is offline
