fast blinkers - Team Camaro Tech
post #1 of 5 (permalink) Old Jan 2nd, 08, 03:27 PM Thread Starter
fast blinkers
All my lights work, the only problem is the blinkers are fast. I have the correct flasher (552) but maybe it needs to be replaced.
Oh yea, my courtesy lights are on all the time, bulbs are out right now,could this be connected somehow?
Thanks, John
Johns 67 is offline
post #2 of 5 (permalink) Old Jan 2nd, 08, 04:14 PM
Re: fast blinkers
Try replacing the flasher with a heavy duty one.
Ron
The “
An exercise in interchangeability on a Well optioned 67 SS 350 vert.
Geezer is offline
post #3 of 5 (permalink) Old Jan 2nd, 08, 04:17 PM
Banned
Ron
Badbird's Avatar
Re: fast blinkers
Most likely that's a 4-way emergency flasher.
Badbird is offline
post #4 of 5 (permalink) Old Jan 3rd, 08, 03:48 AM
Re: fast blinkers
Turn signals flashing fast is a sign of worng bulb(s) 32 watts each, or broken bulb, or wrong flasher. Park/turn (front) for a '67 is 1034, rear turn/park/stop are 1157. Indicators are included in the circuit also, 194. So you have to have the load, three bulbs per side, to have a std flasher work correctly. The more total wattage of the lamps, the faster the flasher flashs. As suggested, a heavy duty or trailer flasher flashs at a predetermined rate, regardless of load, up to six bulbs.
Interior lights, ORG is power. White wire to door switches is ground to complete circuit. Be sure headlamp switch is turned CCW to turn off manual dome light. Full CW headlamp switch turns on dome light with doors closed.
Turn signal flasher is metal case by steering wheel. Four way flasher is plastic and plugs into fuseblock.
post #5 of 5 (permalink) Old Jan 3rd, 08, 03:09 PM Thread Starter
Re: fast blinkers
Thanks! Now I have a couple of things to check.
Johns 67 is offline
