hei distributor - Team Camaro Tech
post #1 of 6 (permalink) Old Jan 4th, 08, 12:12 PM Thread Starter
jerry
JERRYS 69 Z's Avatar
hei distributor
want to put an gm style hei in my 67 327. how should i wire this dist. up?
will it fit? thanks for all info.
jerry
JERRYS 69 Z is offline
post #2 of 6 (permalink) Old Jan 4th, 08, 12:29 PM
Tony
71maligreen's Avatar
Re: hei distributor
run a 12 volt wire(dont remember what gauge) from the ign. male plug at the fuse box to the hei and a wire to a tach (if you have one) from the hei cap. been doin it that way for 20 yrs now no problems yet! make sure you get an early style hei unit (non computer assisted)!
71maligreen is offline
post #3 of 6 (permalink) Old Jan 4th, 08, 12:38 PM
Re: hei distributor
Jerry, one of the great things here at TC is the amount of info available with a search. If you search "HEI fit" you'll see 7 pages fo threads, and more than one of them discuss whether a big cap GM HEI will fit a 1st gen, and which motor mount/frame stand combos seem to provide more clearance than others. Then you figure out what style you have, maybe take a measurement from the center of your existing distributor to the firewall as a double check, and kinda go from there.
As far as power supply, the cleanest way is to remove the existing cloth-covered resistance wire from the engine harness connector and replace it with a 12 gage wire to the "BAT" terminal in the GM HEI; if you just use the resistance wire from the points dist, it won't give a full 12V to the HEI. You can also properly tape up/abandon the yellow wire from the starter to the coil; this was a full 12V supply to the coil/dist only when the key is in "start" and the starter is engaged. Because the HEI will get 12V from the new feed wire you install, you don't need the yellow any more.
Eric
Eric Kammerer is offline
post #4 of 6 (permalink) Old Jan 4th, 08, 02:17 PM
Russell
Send a message via AIM to capt68 Send a message via Yahoo to capt68
Re: hei distributor
jerry
Jerry,
I'm going to send an email to you. I putting a book together. I think I have the info you're looking for.
Russell
capt68 is offline
post #5 of 6 (permalink) Old Jan 5th, 08, 12:13 PM Thread Starter
jerry
Re: hei distributor
thanks guys. this sure sounds simple enough.
post #6 of 6 (permalink) Old Jun 11th, 08, 02:49 PM
TC
Re: hei distributor
Replacing the wire only pertains to HEI only correct? I'm getting ready to switch to a new Mallory/Summit electronic (old points style) and want to make sure the original wire is okay.
6Z8RS is offline
