Instrument cluster ground - Team Camaro Tech
post #1 of 3 (permalink) Old Jan 6th, 08, 01:22 PM Thread Starter
I removed the instrument cluster from my Nova today (basically the same as Camaro) and have one question. There is a black wire attached to the metal piece that ties the wiper switch with the headlight switch (grounding, I assume). This wire was not attached to anything even before I started working on it. It appears to be a ground wire and it looks like it has pulled from its mount position but I don't know where that may be. Looking at the chasis manual, it may attach to a mounting point on the bottom of the carrier to dash metal. Is that correct?
Dave, member number 7704
2000 Dodge Viper GTS
drdave69 is offline
post #2 of 3 (permalink) Old Jan 6th, 08, 01:29 PM
Kevin
KevinW's Avatar
Re: Instrument cluster ground
Correct, the 69 Camaro one grounds the headlight and wiper switch. The black wire should have a flat loop connector at the end and it gets screwed to the metal dash brace nearby.
Kevin
KevinW is offline
post #3 of 3 (permalink) Old Jan 6th, 08, 03:18 PM Thread Starter
Thanks Kevin. What puzzles me is that all of the dash lights, headlight switch and wiper switch worked without this ground wire attached.
drdave69 is offline
