67 RS wiring question - Team Camaro Tech
post #1 of 3 (permalink) Old Jan 7th, 08, 09:28 AM Thread Starter
Matt
I hooked up my 67 RS front lighting harness and I have an extra connector that doesn’t hook to anything.
The connector has a purple wire and a gray (or maybe white or tan) wire going into it. This is not the marker light connector—I hooked that one up. This connector is like the one shown in my drawing—it is a stacked connector, like an = sign.
The two wires come out of the taped cluster next to the voltage regulator and the horn relay. At first, I thought they went to the driver’s headlamp limit switch, but those are single connectors (one white and one brown).
I have everything else connected (RS relays, limit switches, horn relay, voltage regulator, headlight and marker light). The wire is short and it must go to something near the voltage regulator or the headlight.
Does anyone know what this connector is for?
Thanks, Matt
Name:	RS question.jpg
Matt M. is offline
post #2 of 3 (permalink) Old Jan 7th, 08, 10:11 AM Thread Starter
Matt
Re: 67 RS wiring question
You know . . . it probably goes to the hide-a-way motor. I don’t think I hooked that up yet.
Matt M. is offline
post #3 of 3 (permalink) Old Jan 7th, 08, 10:19 AM
That's it. Headlight motor.
1967 Mountain Green RS/SS 396/325HP TH400
1967 Barn Fresh 327 PG
67 C10
2006 Lemans Blue Corvette Z51 6Spd
67L35 is offline
