Looking for suggestions on a 69 Camaro Antenna - Team Camaro Tech
post #1 of 9 (permalink) Old Jan 8th, 08, 06:48 PM Thread Starter
Ed
BigBlock1969RS's Avatar
Lightbulb Looking for suggestions on a 69 Camaro Antenna
Anyone have any suggestions on good 69 Camaro Antenna, or what you have had good luck with both in clean install and actual reception.
Mostly looking for a AM/FM antenna, could be fixed or manually telescoping.
Thanks in advance!
Ed
BigBlock1969RS is offline
post #2 of 9 (permalink) Old Jan 8th, 08, 07:11 PM
Dave C
Re: Looking for suggestions on a 69 Camaro Antenna
I put my antena up high underneath the dash with wire ties that seems to get decent reseption.
PRO.ST69orange
post #3 of 9 (permalink) Old Jan 8th, 08, 07:40 PM
Charlie
Probably not the info your looking for, but I prefer the auto telescoping antenna located on the rear right quarter panel. Charlie 69 RS/SS & 69 RS
camaromaniac is offline
post #4 of 9 (permalink) Old Jan 9th, 08, 07:14 AM
Charlie
I use a power unit. As with any antenna, make sure the attaching nut is stainless along with any hardware that will see weather. Or paint it. I learned the hard way. I get PERFECT reception with my power unit.
67CamaroRS/SS is offline
post #5 of 9 (permalink) Old Jan 12th, 08, 06:37 AM
I also put mine under the dash. In the shop with the door closed,I sill get a great signal. I make for a cleaner look on the outside of the car...
Travis1 is offline
post #6 of 9 (permalink) Old Jan 12th, 08, 06:53 AM
I put mine under dash to.Works fine.
Stainless dog is offline
post #7 of 9 (permalink) Old Jan 12th, 08, 09:33 AM Thread Starter
Ed
Any ideas on the brands or links on under dash antennas? Also what did you guys do to fill in your existing fender antenna hole?
Thanks for all the suggestions.
Ed
post #8 of 9 (permalink) Old Jan 12th, 08, 04:43 PM
Banned
Alan
98blackburb's Avatar
I'm curious on this 1 too, I'm also looking for an under-dash antenna .
98blackburb is offline
post #9 of 9 (permalink) Old Jan 12th, 08, 09:17 PM
If you have existing hole put it in.
