No Brake lights or hazards in the rear - Team Camaro Tech
post #1 of 7 (permalink) Old Jan 14th, 08, 05:27 PM Thread Starter
Ok, here we go again. Brand new wiring harness, headlights work, and yes now the radio works, tail lights work, hazards flash in the front but not the rear and no brake lights in the rear at all. I have installed a new brake light switch also. I even depressed the brake light plunger with my finger, in and out and no sign of life in the rear, only when I put the headlights on, but even then...no brake lights. Any suggestions?
Mochatea396 is offline
post #2 of 7 (permalink) Old Jan 14th, 08, 05:31 PM
Re: No Brake lights or hazards in the rear
Have you checked for a good ground on the rear wiring harness?
468 CID 661 Horsepower
Turbo 400
33"x19.50" Mickey Thompsons
post #3 of 7 (permalink) Old Jan 14th, 08, 06:07 PM Thread Starter
I was pretty sure I had all the grounds good, if I had a bad ground on the rear harness wouldn't I not get any tail lights or license plate light? They all come on fine when the headlights are on, just no brake lights or hazards.
post #4 of 7 (permalink) Old Jan 14th, 08, 06:17 PM
Oops! I wasn't paying attention to all of your post. You mentioned that you checked all the grounds did that include the ground of the brake light switch as well?
Turbo 400
post #5 of 7 (permalink) Old Jan 14th, 08, 06:25 PM
Do the brake lights work when the headlights are OFF?
Do the tail lights go out when yo press the brake pedal?
What do the turn signals do?
Yes to the first 2 = bad ground at the tail light
post #6 of 7 (permalink) Old Jan 15th, 08, 03:09 PM Thread Starter
I would like to thank everyone who responded. After looking at my original harness I see that there are two (2) flashers on the car, one on the fuse panel and the other is on a purple/pink wire combo. After plugging a flasher into it the brake lights worked. I don't know why this other flasher made the difference, maybe it just needed to close the curcuit, now my hazards work in the rear, but I still don't have directional signals.
post #7 of 7 (permalink) Old Jan 15th, 08, 03:16 PM
madmax87's Avatar
Just an FYI, the flasher on the fuse panel is for hazard, the other is for turn signals
madmax87 is offline
