Lime green wire - Team Camaro Tech
post #1 of 9 (permalink) Old Jan 16th, 08, 10:51 AM Thread Starter
Question Lime green wire
I have a lime green wire hanging loose from my speedo cluster on my 67 r/s convert does anybody know where this goes? it looks like it has been torn from somewhere but i have no clue as to where it goes. thanks guys
1967 RS convert 88,000 original miles numbers matching 327 powerglide
DDOLES is offline
post #2 of 9 (permalink) Old Jan 16th, 08, 11:00 AM
Eric
Re: Lime green wire
Is it a twin wire? The back up light switch harness is green.
ERIC
67 Convertible, 350CID, TKO600RR, 3.73 Eaton Posi
ept000 is offline
post #3 of 9 (permalink) Old Jan 16th, 08, 11:01 AM
Re: Lime green wire
the light green wire is the high beam indicator, up there between the instruments.
Eric
Eric Kammerer is offline
post #4 of 9 (permalink) Old Jan 16th, 08, 11:08 AM Thread Starter
Re: Lime green wire
it is a single wire of decent diameter. i think Eric maybe correct i will check this when i get home tonight. Eric where does this wire hook to from the cluster?
DDOLES is offline
post #5 of 9 (permalink) Old Jan 16th, 08, 11:19 AM
Re: Lime green wire
It should have a bulb socket on it. See pic in post #6 this thread:
https://www.camaros.net/forums/showth...indicator+wire
Eric
post #6 of 9 (permalink) Old Jan 16th, 08, 11:22 AM
Re: Lime green wire
See pic in post #4 this thread:
https://www.camaros.net/forums/showth...ment+high+beam
Bulb socket on light (lime) green wire gets inserted into the bracket between the gauges, at the top of JimM's pic.
Eric
post #7 of 9 (permalink) Old Jan 16th, 08, 12:34 PM Thread Starter
Re: Lime green wire
where does the other end of the wire go to?
DDOLES is offline
post #8 of 9 (permalink) Old Jan 16th, 08, 01:02 PM
Re: Lime green wire
It is wrapped into the main underdash harness, and makes it's way to the dimmer switch. It gets energized when the dimmer is clicked to high beam, and it grounds through the metal bracket and instrument cluster ground on the bulb end.
Eric
post #9 of 9 (permalink) Old Jan 16th, 08, 01:38 PM Thread Starter
Re: Lime green wire
thanks Eric im going go home and check this out
DDOLES is offline
