Aftermarket Gauges - Team Camaro Tech
post #1 of 7 (permalink) Old Jan 19th, 08, 01:18 PM Thread Starter
Jason
Aftermarket Gauges
OK, still moving along with my re-wire and getting ready to connect some additional guages. Question I have is, where it states that for example, water temp plugs into the dash cluster in pin x, do I run a jumper from pin x to my aftermarket guage (no factory guages so I assume this powers the idiot lights) or do I connect it directly to my gauge and bypass the dash connection all together?
Thanks in advance,
JD
1968 Camaro Coupe 327 worked over
Omnipotent is offline
post #2 of 7 (permalink) Old Jan 21st, 08, 12:56 PM Thread Starter
Jason
Re: Aftermarket Gauges
Bump for the weekend.
post #3 of 7 (permalink) Old Jan 21st, 08, 01:19 PM
Jon
Rodder's Avatar
Send a message via AIM to Rodder Send a message via Yahoo to Rodder
most people bypass the 40 year old wiring and run new wires for their gauges, particularly to electric gauge sending units that are sensitive to resistance.
- LS1, T56, Hooker longtubes, Autokraft pan & mounts, GM LS7 clutch, Borla ProXS, Moser/Strange/Wilwood 9", Covans dash, UltraLite IIs, Procar Elites, Vintage Air GEN-IV, AGR 12:1 steering, Addco swaybars, Hydratech hydroboost
Rodder is offline
post #4 of 7 (permalink) Old Jan 21st, 08, 02:37 PM
I'm not real clear on what you are trying to do. I know there was another thread or 2 on your rewqiring, but don't recall the specifics or if they relate at all to you gauges.
Where did that come from? What aftermarket gauges are you talking about, I've never seen aftermarket gauges with that level of detail in the instructions, unless you are talking about reproduction factory style gauges...
post #5 of 7 (permalink) Old Jan 21st, 08, 03:25 PM Thread Starter
Jason
I am re-wiring with a factory update kit from AAW. In making all of the connections to the dash cluster which identify various wires, water temp, oil presure and so on. I am adding some additional gauages so that I have a visual of these things. The question is do I run the AAW kit to the dash and then jump to the aftermarket gauge? Do I bypass the dash and go straight to the guage? Or do I connect the AAW kit as described, and then just wire the aftermarket gauge for a switched 12 volt and ground and then add the specific connection (water temp) seperately?
post #6 of 7 (permalink) Old Jan 21st, 08, 05:20 PM
Depends on if you are keeping the idiot lights or not.
Personally, I like idiot lights. They "make you notice them"
If you lose the idiot lights, you can use the wires for the idiot light senders as the sender wires for your gauges. If you keep them, you gotta run more wires and install more senders. Idiot light senders are different than gauge senders.
post #7 of 7 (permalink) Old Jan 21st, 08, 06:23 PM Thread Starter
Jason
Thanks...clears up my questions.
