Anyone Recognize These? - Team Camaro Tech
post #1 of 13 (permalink) Old Jan 20th, 08, 01:49 AM Thread Starter
These 2 rubber sleeves are with my engine harness kit.
One sleeve is for an 18/20 gage wire and the other is for a 12 gage.
The only 12 gage in the engine harness is the Purple to the starter solenoid, so I figure it's on that wire, but I'm not sure and don't know where.
If that's a clue, I'm guessing that the smaller might be for the Yellow wire, also to the starter solenoid.
Maybe they are heat shields or for anti-chafing or something..
Anyone know for sure?
Thanks.
(I got a kit off the guys that make the repro looms, complete, but without wiring as my RHD would need extensive modifactions.)
BlackoutSteve is offline
post #2 of 13 (permalink) Old Jan 20th, 08, 03:26 PM
Dave C
Re: Anyone Recognize These?
They are heat shrinks for splicing. When you solder wires together you slide them over and shrink them with a lighter or a heat gun. They shrink about 60 percent.
PRO.ST69orange
post #3 of 13 (permalink) Old Jan 20th, 08, 10:56 PM Thread Starter
I have heat-shrink tubing and these are definitely a different material.
Not only that, the smallest is a snug fit on the smallest size gage that is on the engine harness. 20 gage
Maybe I'll cut the tinyest piece off and see what happens with the heat gun. I'll let you know.
Thanks.
post #4 of 13 (permalink) Old Jan 21st, 08, 02:50 PM
Todd
Looks like you need to use them in a high friction area or an area where the wires cross a sharp piece of sheetmetal.
Vegas69 is offline
post #5 of 13 (permalink) Old Jan 21st, 08, 03:51 PM
DjD
DjD's Avatar
Not heat shrink, much too thick... Looks like short sections of fuel line to me. I think it's intended use is for where the factory wiring to the starter would bend around the block after it drops down the firewall. Some vehicles have a metal tube down there, others they double wrap the wires...
Why not contact the guys that sent the stuff to you?
...Dennis
DjD is offline
post #6 of 13 (permalink) Old Jan 21st, 08, 04:07 PM
Kevin
I think those are rubber sleeves that go over a wire connection. I don't know why they are used sometimes, but my American Autowire setup used one on the purple wire that goes to the starter solenoid. I don't recall where I've seen another one. I assume they are for extra insulation.
-Kevin
'68 RS Camaro, 454 SBC
'69 Camaro, body only
MissionCritical is offline
post #7 of 13 (permalink) Old Jan 21st, 08, 10:50 PM Thread Starter
Thanks guys, I just might contact them.. I just figured it may have been a really easy answer, so I asked here.
post #8 of 13 (permalink) Old Jan 22nd, 08, 02:34 PM Thread Starter
Jon From American Auto Wire just got back to me and said these rubber sleeves are for protecting the crimps on the ring terminals at the starter.
(Now we all know!)
post #9 of 13 (permalink) Old Jan 22nd, 08, 02:37 PM
Christropher
Mystery Solved!!!
Christropher
...in pieces still.
clwilcox33 is offline
post #10 of 13 (permalink) Old Jan 22nd, 08, 03:43 PM
Dave C
(Now we all know!)
Do these get heat shrunk on or just slide over the wire? I'm curios but that killed the dog.
PRO.ST69orange
post #11 of 13 (permalink) Old Jan 22nd, 08, 04:00 PM
Yes me too, my kit is on the way and would like to know.
hypersport750 is offline
post #12 of 13 (permalink) Old Jan 22nd, 08, 04:25 PM
Kevin
No, these are made out of rubber, you don't heat them or anything. You just slide them over the wire before putting the end on, crimp the end on, then slide it down over the connection as far as you can. They fit pretty tight. Like I said, I think they are for extra insulation and yet flexible, which is better for the tight areas around the starter and you don't want any of the connection to be open for a possible short as there are a lot of wires all coming into the same area, including the main battery cable.
-Kevin
post #13 of 13 (permalink) Old Jan 23rd, 08, 03:28 AM
Curiousity killed the cat, not the dog.
