1969 a/c car - Team Camaro Tech
post #1 of 6 (permalink) Old Feb 26th, 08, 07:40 PM Thread Starter
john
wagonman's Avatar
1969 a/c car
i was under my dash today..
1969 original a/c car.
i noticed that there are two connectors from the underdash harness that are not used!
one looks like a heater resistor connector
the other looks like maybe a heater control or fan speed connector.
they seem to have been taped up from the factory? is this possible?
the heater resistor is under the hood on the evaporator box.
and the fan speed has a connector from the a/c harness.
has this car been "messed" with some time during it's history?
Remember,I'm not making this stuff up!
1969 rs/ss 396 350hp/4spd conv a/c,pw,ps,foldown
1968 Z/28 crossram- j/l8 conv pw,ps,foldown
1963 nova ss 350/4spd conv a/c,ps,pt
1963 nova 400 4dr 6cyl/700r4 a/c
2006 GT/5spd mustang conv
wagonman is offline
post #2 of 6 (permalink) Old Feb 26th, 08, 08:34 PM
Re: 1969 a/c car
Wagonman,
The A/C harness is a seperate harness from the underdash harness, and plugs into the Heater/AC contol unit (with the fan switch), goes through the firwall, and connects to the fan resistor, relay, and other components on the evaporator "suitcase". The under dash harness (that connects to the fuseblock) on an A/C car, does not have the connectors/wiring for the "heater only" components.
At least, this is the way it is on all 3 of my Norwood built '69 A/C cars.
My guess is, someone replaced the underdash harness at some point with the standard "heater only" harness.
Either that, or at some point, or durring some production runs, GM ran out of the A/C underdash harness and used the standard harness on some cars. However, my 3 cars span from December of '68 to Sept. of '69. Or, possibly the California plant used the standard harness in all cars.
Hope this helps.
Keith
awsm502 is offline
post #3 of 6 (permalink) Old Feb 26th, 08, 09:36 PM Thread Starter
john
wagonman's Avatar
Re: 1969 a/c car
thank you....i was hoping to get an answer before i went to bed.
there does'nt seem to be an aftermarket harness for me.
i need a 1969 underdash harness 4 speed console with gauges and factory tach.that doesnt have the heater coneectors.
i was working on it again this eve putting may dash back together again....
it does seem as if Gm put the "wrong" harness in and they tapped it to the a/c harness.
so i will just live with it.....
wagonman is offline
post #4 of 6 (permalink) Old Feb 27th, 08, 11:29 AM
Tim
Havin' Fun's Avatar
Re: 1969 a/c car
Try posting your needs here.
https://www.camaros.net/forums/showthread.php?t=117347
Havin' Fun is offline
post #5 of 6 (permalink) Old Feb 27th, 08, 04:31 PM
Re: 1969 a/c car
GM cut the underdash harness and tapped into it to add the A/C option. Instructions are in the wiring section of RPO C60 in the assembly manual.
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
Mark C is offline
post #6 of 6 (permalink) Old Feb 27th, 08, 08:07 PM Thread Starter
john
wagonman's Avatar
Re: 1969 a/c car
Mark C, thank you.
so i do have the original underdash harness then? so....gm must have forgot to cut it...those two connectors are taped up to the a/c harness......
good news......the car does seem unmolested under the dash....
wagonman is offline
