69 Camaro RS Headlight questions - Team Camaro Tech
post #1 of 3 (permalink) Old Mar 4th, 08, 12:03 PM Thread Starter
Tim
Send a message via MSN to HzEmall
Does the actual headlight switch have vacum ports on it ? The diagram I have shows a tan and a black going right to the switch, I haven't been able to see an actual headlight switch with vacum ports on it. Is there ANY electrical connections to this system or is it strictly vacum ?
Got a customer who's system worked until he took it to some shop, now we have to trouble shoot it. They put in a stereo and totally hacked the car, tied the stereo ground wire to the wire that showed ground (till you pull on the headlights then it wacks a fuse) and I am wondering if they damaged the switch doing this.
HzEmall is offline
post #2 of 3 (permalink) Old Mar 4th, 08, 01:08 PM
Gary
Re: 69 Camaro RS Headlight questions
It has 2 vacuum lines and an electrical harness attached to the headlight switch.
69 rs/ss 350 "vert" air tilt windows
reddoter is offline
post #3 of 3 (permalink) Old Mar 4th, 08, 01:13 PM
click's Avatar
Tim this is what should be attached to the dash.
click is offline
