68 rewire - Team Camaro Tech
post #1 of 3 (permalink) Old Mar 13th, 08, 06:44 AM Thread Starter
jim
Send a message via Yahoo to 67chevelless
68 rewire
I have a 68 standard camaro automatic that I am putting console guages in, I have the under dash and console wiring, will I have to change the engine wiring also or will the guages work that way? It will not have a tac. Thanks Jim
67chevelless is offline
post #2 of 3 (permalink) Old Mar 13th, 08, 10:00 AM
Boo
Re: 68 rewire
I'm putting factory gauges in as we speak. If you want to do this you need the console conversion harness. One other thing the factory gauges has a fuel indicator which makes the dash pod one redundant. Probably a good idea to get the tic toc tach, since the conversion harness is wired for it.
I'm not sure about Autometer or other aftermarket gauges, but I know there are a ton of threads on this.
HTH.
My Ride:
1968 Camaro SS Clone
booman55 is offline
post #3 of 3 (permalink) Old Oct 4th, 08, 11:01 PM
Larry
larryh56's Avatar
Re: 68 rewire
If you are installing gauges into a car with no gauges previously you will need to install sending units for the oil pressure and water temp gauges on the engine.
larry
larryh56 is offline
