67 no power to headlight motors? HELP!! - Team Camaro Tech
post #1 of 10 (permalink) Old Mar 27th, 08, 02:46 PM Thread Starter
jeff
hello all,
i have power to the 10 amp breaker,both sides,i can hear relay #1click when i turn on my headlight switch,i pulled the connector plug from the motor but no power,could the other relay's cause this problem,if not what could it be,thank you for any help. jeff
67RS/SSL35 is offline
post #2 of 10 (permalink) Old Mar 27th, 08, 02:52 PM
Matt
Re: 67 no power to headlight motors? HELP!!
This is a good link for troubleshooting:
http://www.retro-electro.net/FAQ.html
Is this a new install or did they just stop working?
Matt M. is offline
post #3 of 10 (permalink) Old Mar 27th, 08, 03:01 PM
Matt
Here's another. Look at the "1967-69 rs console gauge & headlight wiring diagrams" link:
http://www.gvtc.com/~rlaa/
Matt M. is offline
post #4 of 10 (permalink) Old Mar 27th, 08, 03:21 PM Thread Starter
jeff
They stopped working,i pulled the motor and bench test is,and i works.my test lightshould work at the motor plug,ing on,switch on,but no voltage at the plug,i used the troubleshooting guide and all voltages seem to be ok at the relay's. thanks for all the quick relays,
post #5 of 10 (permalink) Old Mar 27th, 08, 03:28 PM Thread Starter
jeff
I have power to the relay's like i should,if one of them is bad,would there still be voltage at the plug? thanks....
post #6 of 10 (permalink) Old Mar 27th, 08, 03:30 PM
Beware that a bad connection can show full voltage when there is no load, but once a load is applied the voltage goes to zero. Take that into consideration with your test results and perhaps repeat your voltage checks with the motors connected. If the voltage mysteriously disappears, be on the look out for a bad connection.
Also, ground isn't always ground. Just as the power can mysteriously vanish when a load is applied, ground can mysteriously rise to 12V if there is a bad connection in the ground circuit.
dnult is offline
post #7 of 10 (permalink) Old Mar 27th, 08, 03:58 PM Thread Starter
jeff
dave,
hooked the motor up,still no voltage at the plug,i do have voltage to the bottom connector of the limit switch,could one of the relays be at fault? thanks jeff
post #8 of 10 (permalink) Old Mar 27th, 08, 04:15 PM
Matt
Did you check the thick brown wire at the relays? (The back two relays.) Are you getting 12 volts there? I believe the brown wires go to the motor(s).
Is your battery above 12V?
Matt M. is offline
post #9 of 10 (permalink) Old Mar 27th, 08, 05:07 PM Thread Starter
jeff
the problem was ,two of the grounds were loose on the door limit switch's,thanks for everyone's help,....jeff
post #10 of 10 (permalink) Old Mar 27th, 08, 09:41 PM
Thanks for posting back Jeff. Glad you got it fixed.
dnult is offline
