67 RS headlite limit switch test? - Team Camaro Tech
post #1 of 3 (permalink) Old Apr 18th, 08, 01:55 PM Thread Starter
geneo
Wonder how to test 67 RS headlite limit switches to see if they are good....
I took a Multi meter and get resistance on 1 terminal and when I click the button nothing on the other terminal, is this the correct way to test?
gene_sc is offline
post #2 of 3 (permalink) Old Apr 18th, 08, 06:09 PM
Re: 67 RS headlite limit switch test?
Sounds about right. here's a link to a diagram if it helps..
https://www.camaros.net/forums/showthread.php?p=970296
Ron
The
An exercise in interchangeability on a Well optioned 67 SS 350 vert.
Geezer is offline
post #3 of 3 (permalink) Old Apr 30th, 08, 08:33 PM
Sounds good. If you can break continuity by pushing the switch's button, the switch itself is working ok. I took a pack of colored pencils and colored the diagram wiring accordingly. It really makes it easier to trace the wires while you are looking at them on the car.
Melrose RS is offline
