Mini Starter wiring.... - Team Camaro Tech
post #1 of 3 (permalink) Old Apr 20th, 08, 10:18 AM Thread Starter
Matt
Send a message via AIM to 70chevyz28 Send a message via MSN to 70chevyz28
Question Mini Starter wiring....
Hey guys....well right now i still running the orignal Delco starter which i have the Moroso heat shield and a heat wrap on it....sometimes still hard to crank with all the heat the headers put off but it starts pretty well....got a newer delco mini starter that is laying around the garage......it has one big terminal and a small terminal then another big terminal with the ground attached....and i installed recently a new harness with HEI conversion and got a purple and yellow wire i believe........ i know the orignal starter has two small terminals and one big for the negative battery cable....any suggestions be appreciated!
Thanks,
Matt
1971 Chevrolet Camaro RS- 357 SB,built TH350,moser axles,eaton,richmond gears...PTFB/Detriot Speed suspension..etc
1966 Chevrolet C-10-95% orignal,292 I6..big torque
70chevyz28 is offline
post #2 of 3 (permalink) Old Apr 20th, 08, 03:54 PM
Re: Mini Starter wiring....
Mini starters usually don't have a terminal for the yellow wire. If you're using an HEI you don't need it anyway. The big terminal on the mini is for the positive battery cable and the small terminal is for the purple wire. That's it.
69 RS 355 Tremec 5-Speed 4.11's
12run is offline
post #3 of 3 (permalink) Old Apr 21st, 08, 08:12 AM Thread Starter
Matt
cool deal.....thought it was more too it then that...lol
