Alternator Location and Brackets - Team Camaro Tech
post #1 of 16 (permalink) Old Apr 26th, 08, 01:00 PM Thread Starter
Brady
I have a 69 Camaro and it has a 350 block with 327 heads. The issue I am having is I want to move the alternator to the passenger side and need to find the correct brackets. The heads do not have any bolt holes in them, so the bracket probably would have to be bolted to the water pump and intake manifold. Anyone have this same issue and if so, where and what alternator brackets do you have? I want to put power steering in the car and this is the first issue I have run into.
dirtlover is offline
post #2 of 16 (permalink) Old Apr 26th, 08, 02:27 PM
Steps
Re: Alternator Location and Brackets
This is covered in older threads
The lower alternater bracket I made up one out of scrape 5mm plate and got it chromed
Bolts to the 2 water pump bolts, with a u to get around the high part of the water pump.
And use the std top bracket that bolts to inlet etc
Never had an issue in the last 20 yrs.
Steptoe is offline
post #3 of 16 (permalink) Old Apr 26th, 08, 03:27 PM Thread Starter
Brady
Thanks!!!dig through the threads and see if I can find it.
post #4 of 16 (permalink) Old Apr 26th, 08, 08:28 PM
Charlie
Didn't the 69 have the alternator on the passenger side from the factory? 67 and 68 alternator was on the drivers side.
67CamaroRS/SS is offline
post #5 of 16 (permalink) Old Apr 26th, 08, 08:46 PM
Yes, 69 was the first year for long water pump and passenger side alternator.
The OE mounting setup had a lower bracket that bolts to the water pump on one end, and has a through bolt to the head that the alternator slides over. The upper mount bolts to the water pump and one of the intake manifold bolts, and then the bolt at the top of the alternator goes through the slot in the upper bracket.
Eric
Eric Kammerer is offline
post #6 of 16 (permalink) Old Apr 26th, 08, 08:50 PM
This might be the thread Steps was thinking of...
https://www.camaros.net/forums/showth...hlight=bracket
Eric
post #7 of 16 (permalink) Old Apr 26th, 08, 08:58 PM
I have used an old smog pump bracket that mounts to the right lower front
motor mount holes with a small spacer and a short adjuster strap to the water
pump. I think a short pwr/stg belt may fit. It works good and is down out of the way.
bumpybigblok is offline
post #8 of 16 (permalink) Old Apr 26th, 08, 09:07 PM
Steps
Thats the thread
just been looking for a pic...cant a good find one
This is the best I have if u look at the bottom of the alternter real careful
Steptoe is offline
post #9 of 16 (permalink) Old Apr 27th, 08, 08:26 AM
Rick
Camaro67_rcl's Avatar
Send a message via Yahoo to Camaro67_rcl
I used these on mine http://www.alangrovecomponents.com/
Rick
67 RS/SS 355, Autogear M21 (w/Overdrive), 8.5w/3.42
Camaro67_rcl is offline
post #10 of 16 (permalink) Old Apr 27th, 08, 09:36 AM
Charlie
Steps. what is that blue piece bolted near the firewall on the passenger side?
post #11 of 16 (permalink) Old Apr 27th, 08, 04:35 PM
Steps
I was wondering if someone would notice..
I have posted in the last few yrs several engine pics and no one has ever noticed or asked before..
Notice..no fuels lines...no fuel pump
That is the secret to a 13 sec approc 11:1 compression daily driver car that does just over 30 mpg
here it is with no air filter.
An older pic ..lines not laid out or stuff cleaned up.
Wonder who knows what it is?
Steptoe is offline
post #12 of 16 (permalink) Old Apr 27th, 08, 06:47 PM
Greg
Looks like a propane regulator
1969 RS/SS Vert
1031 Engineering llc
chops is offline
post #13 of 16 (permalink) Old Apr 27th, 08, 07:05 PM
Kevin
SixtyAte's Avatar
Yep....A propane regulator
Steps uses GAS I remember back a few years ago, seeing a propane tank in the trunk of the 69...right Steps
Kev
SixtyAte is offline
post #14 of 16 (permalink) Old Apr 28th, 08, 01:29 AM
Steps
Like this?
Been dedicated LPG since '86 even messed a bit with CNG before that...
Steptoe is offline
post #15 of 16 (permalink) Old Apr 28th, 08, 07:13 AM
Charlie
How does it run on Propane? What did it take to make the swap. How long does it last before you have to fill the tank again? Does it run solely on Propane or does it still use gas as well? Is that a carb or what? It doesn't look like a 4BBL. What is that?
