power window hole sizes in body - Team Camaro Tech
post #1 of 6 (permalink) Old Apr 28th, 08, 07:45 PM Thread Starter
Frank
I am helping a buddy of mine to install power windows in his 67 Camaro and I need to know the exact size of the holes in the body and in the doors for the boots. I've done a search and it is not clear (to me) if the size is 2 inches, 1.900 or somewhere in between. I know the door is smaller, I have read 1 3/8 somewhere but is that the boot size or the hole itself ? Just want to make sure before I cut. Frank.
Frank350 is offline
post #2 of 6 (permalink) Old Apr 28th, 08, 08:36 PM
Re: power window hole sizes in body
Check with Dale8346, as he may have this info by now.
capt
captcanuck68 is offline
post #3 of 6 (permalink) Old Apr 28th, 08, 09:32 PM
john
wagonman's Avatar
i used a greenlee punch for 1-3/4 electrical conduint.i beleive it made a 1.90 hole in the cowl.
i used another punch 1 3/8 inch hole in the doors....
now i am pretty sure these are the correct sizes and produced a nice snug fit with the boots.
the best thing to do is get the wiring harnesses first!
then check the boots with your holes on another piece of sheetmetal....
Remember,I'm not making this stuff up!
1969 rs/ss 396 350hp/4spd conv a/c,pw,ps,foldown
1968 Z/28 crossram- j/l8 conv pw,ps,foldown
1963 nova ss 350/4spd conv a/c,ps,pt
1963 nova 400 4dr 6cyl/700r4 a/c
2006 GT/5spd mustang conv
wagonman is offline
post #4 of 6 (permalink) Old Apr 29th, 08, 04:49 PM Thread Starter
Frank
Thanks wagonman, did the holes today and everything fits fine. Frank.
Frank350 is offline
post #5 of 6 (permalink) Old Apr 29th, 08, 06:25 PM
john
wagonman's Avatar
glad to help.......how did you cut your holes?
wagonman is offline
post #6 of 6 (permalink) Old Apr 30th, 08, 04:02 AM Thread Starter
Frank
Traced the circle with a pencil with the help of a pattern, then drilled the pre-punched hole with the biggest drill bit I have which is 5/8 then enlarged it gradually using a die grinder with a carbide cutter. Took a while but I went slowly to make sure it was perfect, tried the boot many times before getting to 1.900 to make sure, finally 1.900 was exactly what was needed. Frank.
Frank350 is offline
