Trouble w/parking light - Team Camaro Tech
post #1 of 4 (permalink) Old May 12th, 08, 08:14 AM Thread Starter
I replaced my headlight switch Sat as it did not really control the dash lights anymore, it was either on or off, with all the dimmer possibilities in between either worn out or the contacts were bad. The new switch went in easy but now my left parking light/turn signal does not work, the rear on the same side works ok. I switch the bulbs from right to left to make sure the bulb was not burned out and the bulb appears fine.
Where do I start in trouble shooting this issue?
67fan is offline
post #2 of 4 (permalink) Old May 12th, 08, 08:36 AM Thread Starter
Re: Trouble w/parking light
The parking light part works fine when the headlight switch is pulled out half-way, it's the directional flasher that does not work.
67fan is offline
post #3 of 4 (permalink) Old May 12th, 08, 08:40 AM
Cisco
battleax's Avatar
Can you hear the same click click of the flasher for the left and right?
1969 Convertible ZZ4/350 Hotchkis TVS West Coast Diff
battleax is offline
post #4 of 4 (permalink) Old May 12th, 08, 08:42 AM
Cisco
battleax's Avatar
Sorry I just reread your first post stating the rear left works nevermind.
battleax is offline
