Brake Lights Stay on After Tremec Swap - Team Camaro Tech
post #1 of 7 (permalink) Old May 22nd, 08, 12:53 PM Thread Starter
Bill
O.k. - I realize it has nothing to do with the tranny, but since I went from auto to manual and isntalled the new pedal assembly I've had this issue where the brakelight switch is not beng pushed in enough when brake pedal is released and returns to normal position. The swith has been adjusted to max setting. I was getting by with a rig-job-spacer on the brake pedal arm that helped for a while but is now intermittent and looking for a permanent fix. Anyobody else been here and found a replacement pedal switch that works well?
68RS-SS is offline
post #2 of 7 (permalink) Old May 22nd, 08, 05:59 PM
Jon
Rodder's Avatar
Send a message via AIM to Rodder Send a message via Yahoo to Rodder
Re: Brake Lights Stay on After Tremec Swap
sounds like you are missing this piece: http://www.rickscamaros.com/product....dept%5Fid=3440
I had the same issue when I converted to power discs, but I didn't know about that piece back then and ended up getting a longer brake light switch at Autozone.
- LS1, T56, Hooker longtubes, Autokraft pan & mounts, GM LS7 clutch, Borla ProXS, Moser/Strange/Wilwood 9", Covans dash, UltraLite IIs, Procar Elites, Vintage Air GEN-IV, AGR 12:1 steering, Addco swaybars, Hydratech hydroboost
Rodder is offline
post #3 of 7 (permalink) Old May 28th, 08, 01:39 PM Thread Starter
Bill
Thanks for posting that helpful info. Does this piece actually mount on the pedal arm?
68RS-SS is offline
post #4 of 7 (permalink) Old May 28th, 08, 02:12 PM
Jon
Rodder's Avatar
I think so... I'm pretty sure I've seen pics of it installed in the Suspension forum on here
Rodder is offline
post #5 of 7 (permalink) Old May 28th, 08, 03:07 PM
Yes. On a power brake car, the brake rod clevis goes through the lower hole, and the striker bolts through the upper. Manual brake cars did not use the striker.
Eric
Eric Kammerer is offline
post #6 of 7 (permalink) Old May 28th, 08, 03:08 PM
Good photo in Post #7 of this thread: https://www.camaros.net/forums/showth...e+pedal+switch
Eric
post #7 of 7 (permalink) Old May 29th, 08, 11:48 AM Thread Starter
Bill
Thanks for that link to photo Eric. It's going to be hard to justify paying $18 plus shipping for that small piece of tin and a bolt so I think I'll attempt to bend my own piece out of some scrap. Appreciate all the help.
68RS-SS is offline
