Horn... Turn Signal.. - Team Camaro Tech
post #1 of 2 (permalink) Old May 27th, 08, 02:42 PM Thread Starter
Chris
So my horn stopped working after I dropped the engine in.. I have no idea if I knocked something off, or what.. any clue what it could be? Its connected at the horn and it couldnt have come out of the steering column, so where does the wire run?
Also, ocasionally my left turn signal doesnt work. it just goes solid.. but then other times it does work.. could this be a bad ground.. or the flasher?
The car is a '69
SunnyZ28 is offline
post #2 of 2 (permalink) Old May 27th, 08, 06:23 PM
Re: Horn... Turn Signal..
Donno about the horn. Wire is black, runs in the lighting harness to the horn relay on the rad support, drivers side.
On the turn signal I'd suspect a bad ground, possibly the front turn signal on that side.
