Mini starter wiring - Team Camaro Tech
post #1 of 3 (permalink) Old Jun 2nd, 08, 07:32 PM Thread Starter
Mini starter wiring
I just purchased a high torque mini starter from Jegs and noticed it only has 2 wire connections. I think I'm only supposed to use the battery cable for one and the wires on the right side of my old solenoid for the other. I belive the left side connections go to the coil and are not needed if using a pertonics ignition system or pointless system. Does this sound correct? Does anyone have any experience with this?
shoughton is offline
post #2 of 3 (permalink) Old Jun 2nd, 08, 07:57 PM
Russ
Re: Mini starter wiring
That is correct , you do not need the little pigtail wire any more with electronic ign.
Russ
1969 RS conv,hugger orange,396 4 speed,373 12 bolt posi.
19694speed is offline
post #3 of 3 (permalink) Old Jun 3rd, 08, 07:20 AM
Len Barron
Unless you have a 67 with the older style ignition switch that doesn't route power to the coil in the "start" position. In that case you'll need to install a diode on the yellow wire that allows flow from the starter to the coil (or hei) during cranking.
Len
67 SS-350 Convert.
406/200r4/12b 3.73's Truetrac
LCAC_Man is offline
