fuel pump wiring - Team Camaro Tech
post #1 of 4 (permalink) Old Jun 4th, 08, 04:13 PM Thread Starter
Trev
madcarson's Avatar
fuel pump wiring
Do I need a circuit brkr in my fuel pump system ? I used a relay,if I need circuit brkr too how do I wire it in and what size ? Thanks
madcarson is offline
post #2 of 4 (permalink) Old Jun 4th, 08, 04:22 PM
Steve69SS396's Avatar
Re: fuel pump wiring
You should use a breaker or fuse with the same amp rating as your relay. Painless relay kit 50102 comes with a breaker. Here is the wiring diagram.
Steve69SS396 is offline
post #3 of 4 (permalink) Old Jun 4th, 08, 04:37 PM Thread Starter
Trev
madcarson's Avatar
thanks
post #4 of 4 (permalink) Old Jun 5th, 08, 01:47 AM
What fuel pump?
Holleys are typically a 7.5 amp fuse.
BlackoutSteve is offline
