67 rs hideaways hair puller - Team Camaro Tech
post #1 of 4 (permalink) Old Jun 5th, 08, 11:43 PM Thread Starter
i am restoring my 67 rs and trying to get the headlamp doors to work. I put new motors, relays,headlight switch and circuit breaker in. used the existing harness which was not complete. i found a wiring schematic on this web site and think i have it wired right. the problem is when you turn the headlights on the doors open but the circuit breaker keeps kicking out continusly and when you turn the lights off with the key on they dont move. unless you move them off the limit switch then it then they close themselves the rest of the way. i am confused on the ground on the relays this black wire was cut and hooked to nothing ungrounded the circuit breaker does not cut out but nothing works not even the headlights disconnect the black and light blue wire from relay 1 black wire grounded headlights work but doors dont open could this be the diode on the brown wire? can anyone help me
carramrod is offline
post #2 of 4 (permalink) Old Jun 6th, 08, 09:44 AM
Re: 67 rs hideaways hair puller
Originally Posted by carramrod View Post
i am restoring my 67 rs and trying to get the headlamp doors to work. I put new motors, relays,headlight switch and circuit breaker in. used the existing harness which was not complete. i found a wiring schematic on this web site and think i have it wired right. the problem is when you turn the headlights on the doors open but the circuit breaker keeps kicking out continuosly and when you turn the lights off with the key on they dont move. unless you move them off the limit switch then it then they close themselves the rest of the way. i am confused on the ground on the relays this black wire was cut and hooked to nothing ungrounded the circuit breaker does not cut out but nothing works not even the headlights disconnect the black and light blue wire from relay 1 black wire grounded headlights work but doors dont open could this be the diode on the brown wire? can anyone help me
Wow! Sounds like you may have some funky grounds. First thing, if you have your relay panel out from it's mounting location while troubleshooting, be sure to ground the panel with another wire because it gets it's ground through the body.
Black wire- the only black one I see on the schematic is on Relay 3 and should be connected to ground, I think on the relay board.
The fact that your door motors want to keep running after the doors have opened suggests your inner limit switches aren't working to cut the 12V motor power. Check for good grounds to the radiator support and that the doors are contacting the pushbutton firmly. Do a continuity check of each switch. One pole should have continuity with the opposite side when the switch is pushed and the other should be continuous when the switch is not pushed.
To confirm the diode is intact, find the 2 wire connector under the dash. Disconnect it and turn on the ignition. If the diode is OK (not open or broken) you should be able to see voltage on the brown wire with a test light. It will be switched by the ignition switch.
I hope this helps. I can post a photo of my relay board and wiring tonight if you need it.
Good luck!
Melrose RS is offline
post #3 of 4 (permalink) Old Jun 7th, 08, 02:40 PM Thread Starter
that would be very helpful if you dont mind thanks for the help
post #4 of 4 (permalink) Old Jun 7th, 08, 04:19 PM
Here's a link to some photos of my relay board and limit switches. I hope it helps. Good Luck!
http://s281.photobucket.com/albums/k...%20wiring/
