1969 Camaro coupe front head light wire harness - Team Camaro Tech
post #1 of 9 (permalink) Old Jul 28th, 08, 06:13 PM Thread Starter
bigsteve
I would like to know if the front wiring harness flips over the ends of the radiator support on both ends of the radiator to the head lights or should they run under the lip the entire lenght?
bigsteve is offline
post #2 of 9 (permalink) Old Jul 28th, 08, 06:52 PM
Codi's Avatar
Re: 1969 Camaro coupe front head light wire harness
The harness travels through the drivers side at the radiator support and is tucked under the top rail of the support to the pass. side.
Daddy's Hot Rod.
Codi is offline
post #3 of 9 (permalink) Old Jul 28th, 08, 07:46 PM Thread Starter
bigsteve
So at no point should it flip over the top to the other side? Any pic would be great. Thanks
bigsteve is offline
post #4 of 9 (permalink) Old Jul 29th, 08, 05:29 AM
What Jim was trying to explain is that when the harness is run the way the factory did it, it is already on "the other side." It goes around the end of the rad support on the driver side, between the end of the support and the fender. Then it goes up and clips on the underside of the channel at the top front of the rad support (you'll see the clip holes starting near where the fender bolts to the support), and then the pigtails for the horns and passenger side headlight drop down from the harness.
I'll try to find some pics.
Eric
Eric Kammerer is offline
post #5 of 9 (permalink) Old Jul 30th, 08, 06:48 PM Thread Starter
bigsteve
bigsteve is offline
post #6 of 9 (permalink) Old Jul 30th, 08, 07:25 PM
468 CID 661 Horsepower
Turbo 400
33"x19.50" Mickey Thompsons
post #7 of 9 (permalink) Old Jul 31st, 08, 06:50 PM Thread Starter
bigsteve
I figured that was the way it went originally. The body shop that worked on it in 1986 must have had a few to many during lunch.
bigsteve is offline
post #8 of 9 (permalink) Old Jul 31st, 08, 07:04 PM
That's a possibility.
Turbo 400
post #9 of 9 (permalink) Old Aug 1st, 08, 12:28 PM
Codi's Avatar
Or maybe not enough.
Daddy's Hot Rod.
Codi is offline
