american auto wire wiring harness - Team Camaro Tech
post #1 of 10 (permalink) Old Sep 12th, 08, 05:23 AM Thread Starter
im building a custom 67 camaro and need a whole new wiring harness and want to hide all wires has anyone used a kit from auto wire or can recomend someone elses complete kit from front to rear all dash etc cheers paul...
milna572 is offline
post #2 of 10 (permalink) Old Sep 12th, 08, 05:29 AM
NICK
Re: american auto wire wiring harness
i have used american autowireing and it is so easy and complete,,there kit rocks and would highly reccomend it, ,all connectors and acc parts are top notch...also long enough to hide as i did,,,good luck and feel free to ask questions if you have and,,kit is approx 495.00
NICKO is offline
post #3 of 10 (permalink) Old Sep 12th, 08, 12:48 PM
Codi's Avatar
I have installed (actually helped install) several AAW kits in early chev cars and i can say they are the best kits around. Clear instructions, wire markings, etc. Just take your time, lay everything out, then begin.
Daddy's Hot Rod.
Codi is offline
post #4 of 10 (permalink) Old Sep 12th, 08, 01:31 PM
frank
Frankrentef's Avatar
AAW, bought 'em, used 'em..... love 'em!
67 Camaro RS - 383 Stroker
Factory A/C - Muncie 4 speed
Frankrentef is offline
post #5 of 10 (permalink) Old Sep 13th, 08, 06:05 AM Thread Starter
cheers mate sounds like the go then thanks
milna572 is offline
post #6 of 10 (permalink) Old Sep 13th, 08, 06:06 AM Thread Starter
thanks mate cheers
milna572 is offline
post #7 of 10 (permalink) Old Sep 13th, 08, 06:06 AM Thread Starter
cheers mate thanks
milna572 is offline
post #8 of 10 (permalink) Old Sep 13th, 08, 06:18 AM
I used the AAW Classic Update kit in my 69, and couldn't be happier. Unlike other generic "GM" kits, AAW takes the time to bunch the underdash harness wires together the correct way, and where factory connectors are needed, the kit has them. They have also made improvements to the harness where appropriate and desirable (for example, the voltage regulator is eliminated since most of us with "restified" cars run an internally regulated alternator, and the horn relay is inside under the dash). If you route the wires along factory locations and use the non-stick vinyl harness tape, you can make it look pretty factory if that's what you want (I did).
The Classic Update for 67-68 Camaros is part number 500661. You can get tech info on the kit from the AAW site, and you can shop that part number online and/or with many of the TC sponsors (MuscleRodz and the GPSuperStore come to mind); you can usually find it for around $450 shipped here in the US, but overseas might be more.
http://www.americanautowire.com/ClassicUpdate.html
http://musclerodzstore.com/index.asp...ROD&ProdID=183
Eric
Eric Kammerer is offline
post #9 of 10 (permalink) Old Sep 14th, 08, 05:15 AM Thread Starter
yea i want to hide all wires building custom 67 art mossison full chassie custom engine bay ,dash etc dont want to be able to see any wires at all so need a custom loom that has longer wires as to hide them,i have sent them a email i was just wanting info as to if they have a good product ....thanks for your info every one seems happy with there product cheers
milna572 is offline
post #10 of 10 (permalink) Old Sep 18th, 08, 03:54 PM
Adam
I'm about ready to start the engine harness from AA for my 69 and was wondering where I can run those long wires out of site and not gonna melt? I would like to avoid putting them along firewall. Thanks
1996jeep is offline
