lighting problems - Team Camaro Tech
post #1 of 6 (permalink) Old Sep 15th, 08, 04:05 PM Thread Starter
lighting problems
ok just replaced the headlight switch to no avail. here is my lighting issues. first off the headlights only work when they are on bright the turn signals work but only have front parking lights with no rear prake lights or running lights when lights are on. whenever i turn head lights on i have one brake light single light on the dash come on and i have no dash lights. plz this is a 68 and if anyone can help this would be great.
z2fast8 is offline
post #2 of 6 (permalink) Old Sep 15th, 08, 04:10 PM
Banned
Ron
Badbird's Avatar
Re: lighting problems
Ground the instrument panel to metal if it isn't already!
Badbird is offline
post #3 of 6 (permalink) Old Sep 15th, 08, 06:00 PM Thread Starter
ok update brake and turns work all around no parking lights in rear, fronts work. headlights work only on highbeam and no dash lights other than one red between gauges.
z2fast8 is offline
post #4 of 6 (permalink) Old Sep 15th, 08, 06:17 PM
Greg
You have multiple problems, there is no "one' fix, but several.
Headlights only on hi-beam? Take out dimmer switch and check. Water probably got on it and corroded internally or the connector itself, or wiring from dimmer toheadlights.
No park lights in rear, assuming the low side bulbs are good, check wiring.
No dash lights, assuming all bulbs are good, the dash lights get ground from the center-top bezel screw. Make sure this screw is intact.
And a wiring diagram/service manual is a must for these old cars, especially if it has had 40 years of halfass wire-hack jobs performed on it (like mine did)
1969 RS/SS Vert
1031 Engineering llc
chops is offline
post #5 of 6 (permalink) Old Sep 15th, 08, 07:49 PM Thread Starter
yea were can i find those little bulb housings i'm missing one. and would all the lights not work if i'm missing one or just a burnt bulb.
z2fast8 is offline
post #6 of 6 (permalink) Old Sep 15th, 08, 09:13 PM
You can purchase replacement bulbs easily from Ricks or Firewheel.
If one bulb is bad should not effect others unless you have a short. Look at replacing the circut membrane on the back of the gauge cluster. The copper traces are thin and may be a problem.
Countryside_Cafe is offline
