Name this starter wire - Team Camaro Tech
post #1 of 4 (permalink) Old Sep 19th, 08, 07:12 PM Thread Starter
Ok so along with cleaning all my grounds and battery terminals, I decided to clean all the starter connections too. But I was wondering what some of the wires do.
There is the main post on the starter that has the big black wire, but also has 2 smaller red wires (1 actually is 2 red wires going into 1 connection) connected to the post for a total of 3 connections(4 wires).
Above that main post is a smaller post with a little purple wire connected to it.
Can someone please tell me what wire is what??
mgray is offline
post #2 of 4 (permalink) Old Sep 19th, 08, 07:29 PM
Re: Name this starter wire
The ones on the big post are your battery cable and fusible links. You have fusible link A that is your power distribution, fusible link B that goes to your ignition switch, and fusible link G that goes to the alternator terminal S. The purple wire on the small post is the start wire. That is if it is for the 1990 IROC.
Oldrocker is offline
post #3 of 4 (permalink) Old Sep 20th, 08, 04:58 PM Thread Starter
Awesome, thanks for the reply!
but why is there a wire going to the alt? doesn't it connect directly to the pos terminal on the battery??
Seems that the starter post is the common connector for everything? I thought the battery post is?
Thanks again
mgray is offline
post #4 of 4 (permalink) Old Sep 20th, 08, 06:03 PM
At the assembly plant when car was made, engine assembly included alternator and the engine shop wired in the alt-to-starter wire.
Later, in the assembly line, engine is joined with the body, all the line person has to do is plug the two-wire connector into the alternator as part of the engine harness. No tools needed on the assembly line there.
