Headlights not working, but Brights do?? - Team Camaro Tech
post #1 of 5 (permalink) Old Sep 20th, 08, 07:18 AM Thread Starter
Fred
77thor's Avatar
On my 69, the headlights don't work but the high-beams(brights) work fine....
All other lights are OK.
I'm thinking that it's a problem with the floor switch....
What do you think??
77thor is offline
post #2 of 5 (permalink) Old Sep 20th, 08, 08:07 AM
Re: Headlights not working, but Brights do??
yup. check for a bad connection their first.
Melrose RS is offline
post #3 of 5 (permalink) Old Sep 20th, 08, 08:09 AM
Dan
I had that problem on another car and it was the relay that would switch between the high & low beams. If the connection at the footswitch is good, change that relay and see if it solves the problem.
Dan
1968 RS - Black
408 w/ Muncie 4 speed & 12 bolt rear
Deluxe Houndstooth Interior
Dropped 2" with TeamIII Mini-Lites
Click for Picture:
funbnme is offline
post #4 of 5 (permalink) Old Sep 20th, 08, 08:52 AM
click's Avatar
Ive never seen any kind of relay with the 69 lights. Just the floor switch and its either the ground of the switch or the wires wiggled loose. The switch goes direct to the lights.
click is offline
post #5 of 5 (permalink) Old Sep 20th, 08, 10:12 AM
James
What do you think??
Make sure both low beam filaments are not burnt out before any in depth troubleshooting.
68 Ragtop is offline
