Tachometer not working - Team Camaro Tech
post #1 of 3 (permalink) Old Oct 5th, 08, 10:10 AM Thread Starter
Ron
My tachometer in the dash is not working. All the wires appear to be connected but not sure. If I was to take it out is there a way to check and make sure the tach itself works. Anyone know which wire from the dash guages is for the tach. Thanks.
rjg67rs is offline
post #2 of 3 (permalink) Old Oct 5th, 08, 12:40 PM
Charlie
Re: Tachometer not working
It may be the filter used if it's a factory tach. The easiest way is to get another tach and use the original wiring. If tach works then you know it's the tach. If not, bad wiring or bad filter.
67CamaroRS/SS is offline
post #3 of 3 (permalink) Old Oct 5th, 08, 07:53 PM
Len Barron
Remove the tach and run jumper wires directly to the coil negative for the signal and to the battery for power and grounds. Fire up the engine and if it still doesn't read you tach is bad.
Len
67 SS-350 Convert.
406/200r4/12b 3.73's Truetrac
LCAC_Man is offline
