Voltage regulator bolts - Team Camaro Tech
post #1 of 5 (permalink) Old Oct 9th, 08, 07:43 PM Thread Starter
What are the correct bolts to fasten the voltage regulator to the core support? The holes in the core support are much larger than the ones in the regulator. Also what type of screw/bolt fastens the horn relay to the core support. 68 car.
fast-charlie is offline
post #2 of 5 (permalink) Old Oct 9th, 08, 07:58 PM
Daryl
1968RallySport's Avatar
Re: Voltage regulator bolts
Go to your local Napa store and ask for # 10 well nuts.
Daryl
1968RallySport is offline
post #3 of 5 (permalink) Old Oct 9th, 08, 08:26 PM Thread Starter
Thanks. I just found a kit at Ricks too.
post #4 of 5 (permalink) Old Oct 12th, 08, 06:08 PM
JohnZ's Avatar
Don't forget to attach the ground wire from the harness to the regulator base - it won't ground through the well-nut mounts, and won't work if it isn't grounded.
JohnZ
CRG
JohnZ is offline
post #5 of 5 (permalink) Old Oct 12th, 08, 07:17 PM
Kevin
KevinW's Avatar
I've got extra from Ricks for my 69 and cant use. The well nuts are for 67 and 68. I will sell them cheaper with less shipping costs! PM me
Kevin
KevinW is online now
