help needed - Team Camaro Tech
post #1 of 7 (permalink) Old Oct 14th, 08, 01:43 PM Thread Starter
help needed
Ok - after painting the dash I started to put it all back together. After I put the instrument cluster back in, I started the car no problem. When I pulled on the headlight switch - first stop parking lights on, second - no headlights...also - speedodometer seems ok but on the fuel gauge, the needle is below E when off and comes up just past E when powered on.
What are your thoughts on the headlight issue. (the bright switch on the floor was not re-installed yet)
For the fuel gauge - just take the cluster back out and move the needle to E manually?
1968 Camaro convertible: 327, 4spd, 12 bolt 3:42, 4bbl
68conv is offline
post #2 of 7 (permalink) Old Oct 14th, 08, 02:12 PM
Banned
Ron
Badbird's Avatar
Re: help needed
Regarding the headlight issue, hooking up the bright light switch on the floor will fix that!
Regarding the fuel gauge issue, grounding the instrument panel will fix that!
Badbird is offline
post #3 of 7 (permalink) Old Oct 14th, 08, 04:06 PM Thread Starter
Re: help needed
Thanks. Where did the little ground wire attach on back of the cluster?
68conv is offline
post #4 of 7 (permalink) Old Oct 14th, 08, 09:33 PM
Re: help needed
Next to the bright light indicator.
Everett#2390 is online now
post #5 of 7 (permalink) Old Oct 24th, 08, 04:07 PM Thread Starter
Re: help needed
OK - thanks for the input
Headlights work since the dimmer installed!
Regarding the fuel guage. Today it actually swept counterclock wise to about the 3 oclock position from about the 5oclock position - still need suggestions please.
68conv is offline
post #6 of 7 (permalink) Old Oct 24th, 08, 06:50 PM
Banned
Ron
Badbird's Avatar
Re: help needed
Check the sending unit ground wire at the rear of the car.....If good then bad sending unit??
Badbird is offline
post #7 of 7 (permalink) Old Oct 25th, 08, 01:22 PM Thread Starter
Re: help needed
Do I have to set the fuel gauge at E or something before I put it in the cluster then the cluster in the dash? Can someone share a diagram of the ground wire please?
68conv is offline
