Battery Voltage Question - Team Camaro Tech
post #1 of 7 (permalink) Old Oct 17th, 08, 04:03 PM Thread Starter
Lifetime Gold Member
Drew
ddx77's Avatar
I am installing a digital amp meter, if the battery is just sitting with nothing attached would a good reading be around 12.5?
I thought I read on another thread (which I cant find now) that it should read 14 while the car is running?
Hopefully this makes some sort of sense.
________________________________
1st Genless again - Working on getting my 69Z28 back.
ddx77 is offline
post #2 of 7 (permalink) Old Oct 17th, 08, 04:15 PM
Re: Battery Voltage Question
Battery sitting at 12.5V is OK; running at 14V is OK (it shouldn't exceed 14.5V running though) - BUT! You are installing an ammeter. That will read amps not volts. Although the 2 are related they are not the same.
67 Camaro: 454/TH400/4.10 12 bolt. Lots of options: PS/PDB/PW, tilt, tach, gauges and more. K-K + 797-Z...
"Politics is the art of looking for trouble, finding it whether it exists or not, diagnosing it incorrectly and applying the wrong remedy" - Sir Ernest Benn
PowerWindows is offline
post #3 of 7 (permalink) Old Oct 17th, 08, 04:19 PM
Try these threads:
https://www.camaros.net/forums/showthread.php?t=70535
https://www.camaros.net/forums/showthread.php?t=70910
https://www.camaros.net/forums/showthread.php?t=71078
post #4 of 7 (permalink) Old Oct 17th, 08, 04:23 PM Thread Starter
Drew
ddx77's Avatar
Thanks Jim!
ddx77 is offline
post #5 of 7 (permalink) Old Oct 18th, 08, 07:58 AM
Charlie
The voltage meter is a much bettery way to monitor your system. An ammeter will only show you a charge or discharge of the system. The voltage meter will show you a physical condition of your system.
67CamaroRS/SS is offline
post #6 of 7 (permalink) Old Oct 18th, 08, 08:56 AM Thread Starter
Drew
ddx77's Avatar
It is a voltmeter that I am installing so that is good news.
I only tested it without the car running and it was at 12.48.
ddx77 is offline
post #7 of 7 (permalink) Old Oct 18th, 08, 09:46 PM
Running should be about 14 to 14.5. A fully charged battery will start at about 13 volts and settle to about 12 volts with no load. During cranking, the voltage should remain above 9 to 10 volts.
dnult is offline
