68 camaro headlights stoped working - Team Camaro Tech
post #1 of 4 (permalink) Old Oct 24th, 08, 01:59 PM Thread Starter
knightmoose's Avatar
Unhappy 68 camaro headlights stoped working
68 camaro everything stock original, headlights stopped working for the first time this morning whyen i went to turn them on nothing, tail lights front parking lamps, turn signal everything else works fine,
Looked under hood everything intact headlight lamps not burned out, i have a square metal box where the lights are at with a cycnder small condesor have no idea if they have anything to do with headlamps, quaetion is if everything else works would you say its the headlamp switch itself as today was out first day under 40 over nite?
it about helping others
knightmoose is offline
post #2 of 4 (permalink) Old Oct 24th, 08, 02:13 PM
click's Avatar
Re: 68 camaro headlights stoped working
bet its the dimmer switch at your left foot floorboard area. Either wire plug pulled loose or the switch lost its ground.
click is offline
post #3 of 4 (permalink) Old Oct 26th, 08, 12:03 PM Thread Starter
thanks it was the headlight switch itself, replaced it 13.99 at autozone, pulled out instrunement guage cluster pretty easy thanks
post #4 of 4 (permalink) Old Oct 26th, 08, 06:48 PM
my bet would have been the dimmer switch too. had it happen once!
69 Camaro RS/SS 350.<br />GM 2.02 angle plug heads.<br />223 dur/480 lift hyd cam.<br />69 z/28 alum high rise.<br />69 z/28 780 vac sec holly carb.<br />4 bolt mains,steel crank,forged flat top pistons.<br />Turbo 350 2800 stall with shift kit.<br />3:73 12 bolt posi.<br />functional ZL2 cowl induction hood<br />gear vender O.D.<br />13.2 in the 1/4 with slicks and open headers
z/27 camaro is offline
