drivers side tail light not as brite as passenger side - Team Camaro Tech
post #1 of 10 (permalink) Old Oct 26th, 08, 06:54 PM Thread Starter
Hi Guys
when friends follow me at nite in my 69 camaro they always say that my drivers side tail lights are not as brite as the passenger side tail lights. i have changed all 3 plugs/sockets on the drivers side and all the bulbs on both sides. the drivers side still appears to be a not as brite.
could it be a grounding problem?? where are the tail lights grounded?
any thoughts??
69 Camaro RS/SS 350.<br />GM 2.02 angle plug heads.<br />223 dur/480 lift hyd cam.<br />69 z/28 alum high rise.<br />69 z/28 780 vac sec holly carb.<br />4 bolt mains,steel crank,forged flat top pistons.<br />Turbo 350 2800 stall with shift kit.<br />3:73 12 bolt posi.<br />functional ZL2 cowl induction hood<br />gear vender O.D.<br />13.2 in the 1/4 with slicks and open headers
z/27 camaro is offline
post #2 of 10 (permalink) Old Oct 26th, 08, 07:22 PM
Jon
Re: drivers side tail light not as brite as passenger side
Might be the ground, but not likely if the turn signals work correctly. You might remove the lenses and wash the insides of them, and see that the inside of both housings are the same color. Also, white reflects light better than any silver paint. If you don't believe that, ask any painter what all colors are used to mix up silver paint.
Jon N
dyno jonn is offline
post #3 of 10 (permalink) Old Oct 26th, 08, 11:25 PM
Steps
Did you solder the wires into/on the connectors inside the sochet unit..espec the black ground wire....as check the other end, I believe it grounds to the body on or beside the strut that holds the trunk catch.
Steptoe is offline
post #4 of 10 (permalink) Old Oct 27th, 08, 08:08 AM Thread Starter
thanks Jonn......i have changed both lenses with brand new ones but didnt really pay attention to the color inside the housings. i do remember that the paint inside wasnt that great......they are painted silver? right? this is what you are trying to say? that i could paint the one thats not that brite...white?? my signals work fine.
thanks steptoe....ill check the ground by the trunk catch. does it ground anywhere else do you know? the new sockets came from GM with pigtails so im assumming there soldered together properly.
post #5 of 10 (permalink) Old Oct 27th, 08, 01:42 PM
Steps
When I restored my tail lights last body rebuild...
I cleaned and degeased the reflector surface inside and use some of that model chrome aersol paint...still like new
I also used to do the high lights on the dash...spray a bit into the lide and used a cotton bud cearfully draged along the raised bits....again degreased and wiped with thinners 1st.
Steptoe is offline
post #6 of 10 (permalink) Old Oct 27th, 08, 03:23 PM
Check the voltage drops in each leg of the headlamp circuit. Meaure battery (-) to the ground pigtail. You should see less than 0.1 volt. Then measure battery (+) to each hot feed (low and high beam). Again you should see less than 0.1 volt.
Do these tests for each side. If your numbers all come out less than 0.1 volt, there is something different about the headlamps themselves. I suspect you'll find one of those tests gives you a higher reading which indicates a bad connection in that circuit.
dnult is offline
post #7 of 10 (permalink) Old Oct 27th, 08, 05:58 PM Thread Starter
dnult....its my drivers side tail light.......not my head lights.
steptoe..........thanks for the tips.
post #8 of 10 (permalink) Old Oct 27th, 08, 09:57 PM
Steps
Same principle for the tail lights, and whil u have the multi meter out check for resistance from the gound to the body.
Steptoe is offline
post #9 of 10 (permalink) Old Oct 28th, 08, 02:53 PM
Originally Posted by z/27 camaro View Post
dnult....its my drivers side tail light.......not my head lights. .
Head lights, tail lights, bud lights...one of these things is not like the other one.
Point being that a voltage drop test is fool proof. It does seem weird to measure something and call a near zero result good. When you've got two of the same thing that are not working the same, things get even simpler.
dnult is offline
post #10 of 10 (permalink) Old Jul 29th, 09, 07:39 PM Thread Starter
it was the inside of the taillight.... the reflector surface that was my problem. on one side the paint was falling off and a wee bit different color. so i re-sprayed both an argent silver......now both lights are the same brightness when driving behind the car in the dark.
