How to wire car to use a 120v outlet to run stereo? - Team Camaro Tech
post #1 of 9 (permalink) Old Oct 29th, 08, 01:49 PM Thread Starter
We currently have a 1988 Camaro that has been modified to look like a police car with lights and sirens. It also has a pretty nice stero installed by car toys. This car is for a non-profit called "Code 3 Response" and we take it around to shows and events for the kids to see, we will also be racing it at Banidemer for the Colorado State Patrol, Take it to the Track events.
My question is can anyone help me out with wiring the car somehow to allow us to plug the car in at events to a 120v normal outlet and run the stereo and lights without draining the battery?
Thanks, Scott
sjacksonco is offline
post #2 of 9 (permalink) Old Oct 29th, 08, 02:04 PM
Re: How to wire car to use a 120v outlet to run stereo?
Put a big AC powered battery charger on it.
"For those that will fight for it...FREEDOM ...has a flavor the protected shall never know."
Semper Fi! L/Cpl Edwin L. "Tim" Craft, B Co 3rd AT's, Khe Sanh Combat Base, February, 1968
onovakind67 is offline
post #3 of 9 (permalink) Old Oct 29th, 08, 02:10 PM
Chris
or http://www.nextag.com/12v-120v-inver...78F01C9C17B9B7
'69 SS X66 Camaro
454, TH400 & GearVendor, 12 bolt
'82 Corvette.
stock
'81 Camaro Pro Bracket car.
406, TH350, 10 bolt, NHRA #3148
82Vettrin is offline
post #4 of 9 (permalink) Old Oct 29th, 08, 02:53 PM
Jon
Rodder's Avatar
Send a message via AIM to Rodder Send a message via Yahoo to Rodder
Originally Posted by 82Vettrin View Post
Those inverters are for running 120V appliances from 12V, he's trying to do the opposite. A battery charger is what he wants. The downside to battery chargers is that most of them put out really dirty/noisy power, and may cause interfence on the stereo. I'd try a battery charger first and see how the noise level is, and then go investigate better/cleaner power supplies if needed.
- LS1, T56, Hooker longtubes, Autokraft pan & mounts, GM LS7 clutch, Borla ProXS, Moser/Strange/Wilwood 9", Covans dash, UltraLite IIs, Procar Elites, Vintage Air GEN-IV, AGR 12:1 steering, Addco swaybars, Hydratech hydroboost
Rodder is offline
post #5 of 9 (permalink) Old Oct 30th, 08, 08:58 AM
I'm with Jon on this one. Try the charger first and if you don't have an 60 cycle hum then you've found the simplest and cheapest way of doing what you want. The battery will act like a giant capacitor and may eliminate any hum problems.
Astron makes some pretty decent regulated power supplies if you need cleaner power.
dnult is offline
post #6 of 9 (permalink) Old Oct 30th, 08, 09:38 AM
DjD
DjD's Avatar
I'd forget about trying to use commerical AC, it's just not going to be available to you at every show and event you go to. Do like the boomers, show tuners and RVers do and get batteries designed to support long hours of use between recharging.
...Dennis
DjD is offline
post #7 of 9 (permalink) Old Oct 30th, 08, 10:04 AM
Greg
Being an ham radio operator, I had not too many years ago a great big 1500w RF-HF amp in a car. I bought a Sears Diehard marine battery (they are designed to deep cycle without damage) , installed in parallel with the existing charging system, and a blocking diode inline. The diode prevents any auxillary components from draining your primary car battery, but it will allow the alternator to charge the aux battery. Worked great.
1969 RS/SS Vert
1031 Engineering llc
chops is offline
post #8 of 9 (permalink) Old Oct 30th, 08, 10:31 AM
Chris
U R correct Jon,, my bad on that link..
what I had in mind was this, like an RV uses:
http://www.progressivedyn.com/prod_d...pd9245c_2.html
I linked before I thinked ..
he could find an RV salvage yard and pick one of those up for practically nothing.. they filter the current to avoid noise, and monitor the battery level to prevent overcharging...
taking into consideration the availibility of 110v at the shows where he intends to go, as Dennis mentions.
'69 SS X66 Camaro
'82 Corvette.
stock
post #9 of 9 (permalink) Old Oct 30th, 08, 08:34 PM
Jeff
yellow69RS's Avatar
A continuos duty solenoid between two batteries will allow you to run the secondary battery completely dead and still start the car. The solenoid needs to energize with ignition current and the lights and stuff wired to the secondary battery only. When the car is started the solenoid pulls in and charges the secondary battery. I've done this on a few trucks with slide in campers.
Jeff
yellow69RS is offline
