Another neutral safety switch question - Team Camaro Tech
post #1 of 3 (permalink) Old Nov 11th, 08, 06:25 AM Thread Starter
Bill
I realized last night that my 6-speed (T56) does not have an integral neutral safety switch like I thought... I guess I must've confused the 5-speed (TKO) with the 6-speed. Looking at what I've got to work with and taking into account that I have a very strong desire not to disassemble the pedal assembly I finally decided that the easiest solution would be to fab a bracket to hold a switch at the clutch clutch pedal. It looks pretty straight forward except for some fairly tight access issues (I'll have to stretch my muscles before attempting this). I plan on using the same type of switch that I used on the brake pedal for this function. My question is this: Can this switch be simply hooked up in series (and handle the current) or does this switch need to feed a relay? I've looked through quite a few posts on this and other site and I'm pretty sure that it will handle it but I just wanted to make sure before I button everything up.
FrankenChevy is offline
post #2 of 3 (permalink) Old Nov 11th, 08, 08:03 AM
Re: Another neutral safety switch question
A brake light switch is not set up to handle the current from the ignition switch; just look at the difference between the wire gage of the purple and purple/white ignition wires (12 gage in and out) and the orange (14 gage) and white (20 gage) brake light wires.
I'm a little confused about the "wire in series" part of the question too. The clutch safety switch will just go in line in place of the factory neutral safety switch; it should have the 12 gage purple/white coming in from the ignition switch and the 12 gage purple from the starter coming out. It is not in series with any other switches.
A relay is needed on a TKO if you use the TKO's NSS; for what you're doing, no relay is needed if you use the right clutch switch.
You need to use either a clutch safety switch from a later car (I have no idea how they are mounted and triggered), or just use a 69 setup. If you search "clutch safety switch" here you should find pics of my OE setup, and there are threads about other guys backfitting the 69 setup to their cars.
Eric
Eric Kammerer is offline
post #3 of 3 (permalink) Old Nov 11th, 08, 08:55 AM Thread Starter
Bill
Thanks for the input. I guess I'll will look for a clutch safety switch to use instead of using a brake light switch (I thought that they may actually be the same switch). I'll have to look into the physical size of the clutch switch because I am extremely tight on space in that area. If I can't fit it in the space then I'll go ahead and use a brake switch and drive a relay with it (since I can mount the relay anywhere under the dash).
As far as the "wire in series" part of the question, "series" is an electrical term to denote "in-line" wiring of a switch as opposed to "wiring in parallel" which denotes wiring along side of something (switch, resistor, etc).... that's about all I remember from my DC circuits class.
