Wont turn off ! - Team Camaro Tech
post #1 of 7 (permalink) Old Nov 14th, 08, 03:23 AM Thread Starter
Gav
USA69Z's Avatar
Wont turn off !
Hey Guys , ive just had a new engine installed in my 69' , its got all the usual goodies, also an MSD 6al set up , dissy and coil. Its all running fine but dosnt turn off now. An auto electrician says that because of the increased spark it trickles thru when ignition is turned off and keeps the motor running.
So what we had to do was put a 4 watt globe spliced into main ignition lead to coil , which draws just enuf from system to let engine stop.
How does all this sound? Has anyone heard of this with the MSD set up?
Im not sure if this is the best outcome, any ideas?
Thanx in advance !
Blacky
USA69Z is offline
post #2 of 7 (permalink) Old Nov 14th, 08, 04:11 AM
Re: Wont turn off !
Reads like the MSD set-up is not wired correctly or the yellow wire from the starter is wired wrong on the solenoid providing power all the time. Yellow solenoid wire should be connected to "R" terminal on solenoid - only on when in start position.
You might bypass the MSD at the coil with the supplied two jumpers after disconnecting the MSD box from the coil.
Welcome aboard, Mate.
Everett#2390 is online now
post #3 of 7 (permalink) Old Nov 14th, 08, 06:16 AM
prostreet69camaro's Avatar
Re: Wont turn off !
The problem is the alternator is feeding power to the MSD box when you turn the ignition off. You need to add a diode to the small wire on the alternator. Go to MSD website and they have a tech forum. It explains a run on condition which is what you have.
prostreet69camaro is offline
post #4 of 7 (permalink) Old Nov 14th, 08, 06:18 AM
Re: Wont turn off !
http://www.msdignition.com/page.aspx?id=3296
"For those that will fight for it...FREEDOM ...has a flavor the protected shall never know."
Semper Fi! L/Cpl Edwin L. "Tim" Craft, B Co 3rd AT's, Khe Sanh Combat Base, February, 1968
onovakind67 is offline
post #5 of 7 (permalink) Old Nov 14th, 08, 06:39 AM Thread Starter
Gav
USA69Z's Avatar
Re: Wont turn off !
Thats unreal , thanx a bunch, ive checked out the MSD site and printed a copy .Ill take it along and show my mechanic. Thanx again!
Blacky
USA69Z is offline
post #6 of 7 (permalink) Old Nov 14th, 08, 11:18 AM
Re: Wont turn off !
An alternate diode is available from most electronics sources, I get these from Fry's Electronics, aren't expensive.
NTE is the manufacturer, 116 is the actual part, p/n NTE-116. Cathode end, with the silver band, twords the alternator.
Regards,
Milton
The Devil's advocate is offline
post #7 of 7 (permalink) Old Nov 14th, 08, 11:48 AM
Lonnie
Lonnie P's Avatar
Re: Wont turn off !
I got them at Radio Shack.
Lonnie P is offline
