Battery cable bulkhead connector - Team Camaro Tech
post #1 of 10 (permalink) Old Nov 14th, 08, 11:10 AM Thread Starter
I'm running a trunk mounted battery. I want to bring the positive cable forward to the engine firewall and then put a bulkhead connector on the firewall instead of just running the cable thru a hole. Does anyone have a good source for something like this that's nice and clean and neat? This is the engine compartment that it's going in so it needs to be very sanitary..........
Lance-w is offline
post #2 of 10 (permalink) Old Nov 14th, 08, 12:06 PM
Len Barron
Re: Battery cable bulkhead connector
Check out the Waytek Wire website.
Len
67 SS-350 Convert.
406/200r4/12b 3.73's Truetrac
LCAC_Man is offline
post #3 of 10 (permalink) Old Nov 14th, 08, 12:15 PM
I would rather have a feed-thru hole with a grommet than a bulkhead connector, unless the connector has insulated covers on both sides. You are also introducing two more connections to cause you trouble.
"For those that will fight for it...FREEDOM ...has a flavor the protected shall never know."
Semper Fi! L/Cpl Edwin L. "Tim" Craft, B Co 3rd AT's, Khe Sanh Combat Base, February, 1968
onovakind67 is offline
post #4 of 10 (permalink) Old Nov 14th, 08, 02:14 PM
Todd
DSE has them. It eliminates the chance of a short to ground. Very important on a positive cable!!!
Vegas69 is offline
post #5 of 10 (permalink) Old Nov 14th, 08, 03:07 PM
What kind of cover do they use?
post #6 of 10 (permalink) Old Nov 14th, 08, 03:14 PM
prostreet69camaro's Avatar
This is the one that I use from Moroso or Summit. I ran my cable inside the car and it connects on the passenger floorboard. I made the hole where the small opening is that is in your picture. It is in that small square hole on the lower pass fire wall under your A/C bulkhead. Then ran a short cable to the starter. Plus I have a ford solenoid in my trunk so that wire is not hot unless it is in the start position.
http://store.summitracing.com/partde...5&autoview=sku
prostreet69camaro is offline
post #7 of 10 (permalink) Old Nov 14th, 08, 03:49 PM
Todd
That's the one.
Vegas69 is offline
post #8 of 10 (permalink) Old Nov 14th, 08, 03:55 PM
Dave C
I put mine down at your feet next to the pass. side bodymount it is nice there it can be reached to charge the battery.
PRO.ST69orange
post #9 of 10 (permalink) Old Nov 14th, 08, 08:45 PM
Ed
BigBlock1969RS's Avatar
Any ideas on what to cover the connector with?
Ed
BigBlock1969RS is offline
post #10 of 10 (permalink) Old Nov 15th, 08, 07:56 AM
Mine is covered by the carpet on the inside of the car. On the outside since it comes thru the square hole in the fire wall support, it is covered with the metal. I cut a hole on the right side of that support and my wire goes thru that hole to the starter.
Here is a older picure. I have replaced the wire with a longer wire that is not touching the fuel line. I made a cover for the square hole on the firewall but you can see the wire coming out of the right side of the firewall so it is protected.
