Fuel Gauge problems - Team Camaro Tech
post #1 of 8 (permalink) Old Nov 16th, 08, 07:54 AM Thread Starter
Dennnis Giles
Fuel Gauge problems
Fuel Gauge not working on 67.I suspect a broken wire between gauge and sending unit. If I hook a new wire to sending unit in trunk and back of gauge to confirm this, which side of gauge do I hook it to? There are three screws on back of gauge. Thanks for any help.
Deny411 is offline
post #2 of 8 (permalink) Old Nov 16th, 08, 08:27 AM
mccorry's Avatar
Re: Fuel Gauge problems
It will go to one of the blades.... not the bolts.... There should be 2 blades.....
Steve -
'69 Camaro RS/SS-350, TH350, factory air, factory AM/FM, factory tilt wheel, console w/ gauges - Daytona Yellow
- 1969 Van Nuys Camaro Database
mccorry is offline
post #3 of 8 (permalink) Old Nov 16th, 08, 08:46 AM Thread Starter
Dennnis Giles
Thanks Steve, Don't have any blades just three screws.
Deny411 is offline
post #4 of 8 (permalink) Old Nov 16th, 08, 09:30 AM
If you follow the traces on the PCB... the one that goes to the tan wire on the dash harness connector is the one you want.
post #5 of 8 (permalink) Old Nov 16th, 08, 10:15 AM Thread Starter
Dennnis Giles
Thanks Jim, That means I will have to pull the dash? I wanted to avoid that.
Deny411 is offline
post #6 of 8 (permalink) Old Nov 16th, 08, 10:28 AM Thread Starter
Dennnis Giles
I ran the new wire to the passenger side of the gauge.(50/50 guess!)
From sender I get 20.2 Ohms
With all wires disconnected needle goes to 3 o'clock
New wire from gauge to ground in trunk, sw. on, needle goes to empty.
So why is this not working?
Deny411 is offline
post #7 of 8 (permalink) Old Nov 16th, 08, 10:31 AM
At least those 2 sentences = it's working.
post #8 of 8 (permalink) Old Nov 16th, 08, 11:43 AM
Banned
Ron
Badbird's Avatar
I remember I had a problem with my fuel gauge!....I think it was something like if I turned the headlight switch on, the gauge worked normal, and if I turned the headlight switch off, the gauge would drop to empty or it could have been vice versa!....Anyway, the gauge wasn't getting a good ground at the instrument panel so make sure the panel is grounded properly!
Badbird is offline
