dash lights and turn signals - Team Camaro Tech
post #1 of 2 (permalink) Old Nov 16th, 08, 01:22 PM Thread Starter
Hey guys, I have looked in the past posts and I think I Know what the problem is but
I cant seam to fix it. From what I have read I think it could be a ground issue. So here we go, I just got my car back from the paint shop and now the dash lights are not working, and when I turn my left turn signal on both the sides blink. I can turn my right signal on and it seams to be working fine. Both lights on the left side blink at once and only the one on the outside blinks on the right. By the way this is on the rear. I have ground the metal where the nuts are bolted but still not working correctly. My car is a 67 rs. Thanks in advance for any help.
gsmith is offline
post #2 of 2 (permalink) Old Nov 26th, 08, 04:03 AM
Roger
Re: dash lights and turn signals
Try checking the actual sockets where they ground to the housing, they need a good ground too. Another area would be the center screw that holds your instrument panel in the dash (right above the high beam indicator).
Roger 67 RS/SS350
Roger344 is offline
