Signal indicators always on - Team Camaro Tech
post #1 of 10 (permalink) Old Nov 22nd, 08, 04:49 AM Thread Starter
Roger
strange problem...67 RS/SS 350....my turn indicators are both lit up when I turn on the lights....signals work OK but my horn also stopped working...new horn relay...new horn...new VR....any ideas ?
Roger344 is offline
post #2 of 10 (permalink) Old Nov 22nd, 08, 06:19 AM
Re: Signal indicators always on
With almost 100% certainty, I will say - bad ground.....................
Dave F. in Rhode Island
Chevy-SS is offline
post #3 of 10 (permalink) Old Nov 22nd, 08, 07:14 AM Thread Starter
Roger
I cleaned the ground at the screw above the high beam indicator and it fixed the indicator problem(but not the horn)....but now the right signal doesn't work
Roger344 is offline
post #4 of 10 (permalink) Old Nov 22nd, 08, 07:59 AM
that signal has a bad groud at the bulb
post #5 of 10 (permalink) Old Nov 22nd, 08, 08:44 AM Thread Starter
Roger
I'm assuming you mean the bulb in the trunk ? Not the indicator bulb ?
Roger 67 RS/SS350
Roger344 is offline
post #6 of 10 (permalink) Old Nov 22nd, 08, 09:00 AM
Jeff
yellow69RS's Avatar
Or maybe the front. I'd look at and clean as many as i can find. This might be more of an issue with a newer resto than and older one if the paint was not removed when attaching grounds on reassembly.
Jeff
yellow69RS is offline
post #7 of 10 (permalink) Old Nov 22nd, 08, 09:02 AM
correct, in the trunk.
bulb socket needs to ground securely to tail light housing, which then grounds to tail pan by mounting studs and nuts.
If both bulbs (RS tail lights?) are bad, it probably needs a star washer or two under the housing mounting nuts.
post #8 of 10 (permalink) Old Nov 22nd, 08, 09:58 AM Thread Starter
Roger
I guess the only thing that confuses me is that both signals worked fine until I grounded the dash cluster to fix the indicator lights....that's when the right signal stopped...I will go make sure all sockets are grounded....and I appreciate all the help so far
Roger 67 RS/SS350
Roger344 is offline
post #9 of 10 (permalink) Old Nov 22nd, 08, 10:15 AM
prostreet69camaro's Avatar
Bad grounds make all kinds of electrical issues. I would clean all the grounds on your front and back lights and blinkers.
prostreet69camaro is offline
post #10 of 10 (permalink) Old Nov 22nd, 08, 11:11 AM Thread Starter
Roger
Problem solved ! The grounds checked out so I went back to the instrument cluster....the steering wheel wire harness connector came loose when I grounded the instrument cluster to fix the indicators...solved the horn problem too...thanks everybody...and now how do I stop obsessing over something that I probably won't drive till spring anyway ?
Roger 67 RS/SS350
Roger344 is offline
