First Gen wont start with the switch - Team Camaro Tech
post #1 of 11 (permalink) Old Nov 30th, 08, 05:23 AM Thread Starter
Question First Gen wont start with the switch
Hey guys,
I tried to start my 1967 last night and no luck. it wont even turn over. I did cross the starter over and it cranks fine that way. I checked the switch and it works fine. I also checked the neutral safety switch and it seems fine. I have never had this problem before. It has a 327 with pg and hei distributor. I was thinking it might be a ground but am open for suggestions. I am at work right now and would love some ideas to try when i get home. Thanks
1967 RS convert 88,000 original miles numbers matching 327 powerglide
DDOLES is offline
post #2 of 11 (permalink) Old Nov 30th, 08, 07:21 AM
Charlie
Re: First Gen wont start with the switch
How did you check the switch? When you turn the key, do you get a voltage drop? You may have a connection problem between the battery cable and the starter. Battery cables can go bad and they usually go bad from the inside out. Also, if there is ANY corrostion on the battery terminals, clean it off and then make sure the connections are tight. You don't have to crank down on them. Just tight enough so they don't spin by hand, then give it about another 1/16 of a turn.
67CamaroRS/SS is offline
post #3 of 11 (permalink) Old Nov 30th, 08, 07:39 AM Thread Starter
nope all new cables and engine harness
DDOLES is offline
post #4 of 11 (permalink) Old Nov 30th, 08, 09:41 AM
Dave,
The starter circuit is 2 parts, the "crank" and the "trigger"
You've all ready tested the crank by jumping the solenoid, that part is fine.
Another worthy test is to try to crank the car with the headlights on.
Headlights dim to nothing = bad starter or dead battery
Headlights dim some, but no cranking = bad solenoid on starter
Headlights don't dim at all = no trigger getting to solenoid
And there's always the "clunk test"
One big loud clunk = bad starter
light clunk, motor tries to turn = dead battery
solenoid buzzing = bad solenoid, loose or burned violet wire, dead battery
not a sound = open violet wire, no trigger power to solenoid.
From your description, Id say you are dealing with "no trigger power on the violet wire."
Could be ignition switch, neutral safety switch, or connections at ignition, console, firewall, or starter itself.
post #5 of 11 (permalink) Old Nov 30th, 08, 09:48 AM Thread Starter
Thanks Jim,
Sadly i think you just confirmed my suspicions
DDOLES is offline
post #6 of 11 (permalink) Old Nov 30th, 08, 09:52 AM
lol, which suspicions?
Let us know how it turns out?
post #7 of 11 (permalink) Old Nov 30th, 08, 09:58 AM Thread Starter
I was thinking it was going to be dash work. I checked all of the connections under the hood. Dash work is the least favorite for me....my big behind doesnt fit under the dash very well
DDOLES is offline
post #8 of 11 (permalink) Old Nov 30th, 08, 09:58 AM Thread Starter
Thanks Jim
DDOLES is offline
post #9 of 11 (permalink) Old Nov 30th, 08, 10:07 AM
ROTFLMAO!!!
4 bolts to pull the seat, that's what I do before any dash work
Get the top off the console first, it's easier.
Unfortunately, I'm betting you will find the terminal for either the violet, or the red wire burned up on the ignition switch.
post #10 of 11 (permalink) Old Nov 30th, 08, 10:29 AM Thread Starter
Well i have checked those wire terminals there so now i will have to trace the wires down to their roots
DDOLES is offline
post #11 of 11 (permalink) Old Nov 30th, 08, 05:10 PM Thread Starter
I found the problem!!!!! the ignition wire going from the distributor to the starter some how got out of the wire loom and killed its self on the exhaust manifold and in turn i guess with all of the playing with it trying to get the darn thing fire up ruined the safety switch i know this because i checked the neutral safety switch last night oh well off to NAPA i go!! thanks guy for your suggestions
DDOLES is offline
